markblack77 Posted October 26, 2016 Share Posted October 26, 2016 I might have got this wrong, so bear with me. If you are recording guitar and mic at the same time and sending them via USB 1/2 how do you make it so the guitar ONLY goes to USB 1 and vocals got to USB 2. At the moment I can only see how to send them to USB 1/2 at the same time and obviously i then get both guitar and vocals combined on both tracks. Cheers Mark Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 26, 2016 Share Posted October 26, 2016 Rather than trying to split USB1/2, try reassigning your mic output block to USB3/4. Then create two stereo tracks for recording in your DAW. Set the record inputs to USB1/2 on one track to record your guitar and set the inputs on the other track to USB3/4 to record the vocals. That way you can continue to use and record any stereo FX you want to assign for your guitar and vocals signal paths in Helix. Quote Link to comment Share on other sites More sharing options...
duncann Posted October 26, 2016 Share Posted October 26, 2016 In addition to what silverhead said, it would be a good idea to record two more tracks at the same time corresponding to USB7 (guitar by default) and USB8 (mic by default) for the dry tracks. 1 Quote Link to comment Share on other sites More sharing options...
markblack77 Posted October 26, 2016 Author Share Posted October 26, 2016 Rather than trying to split USB1/2, try reassigning your mic output block to USB3/4. Then create two stereo tracks for recording in your DAW. Set the record inputs to USB1/2 on one track to record your guitar and set the inputs on the other track to USB3/4 to record the vocals. That way you can continue to use and record any stereo FX you want to assign for your guitar and vocals signal paths in Helix. In addition to what silverhead said, it would be a good idea to record two more tracks at the same time corresponding to USB7 (guitar by default) and USB8 (mic by default) for the dry tracks. thanks for all that. Quote Link to comment Share on other sites More sharing options...
malhavok Posted October 26, 2016 Share Posted October 26, 2016 USB 1/2 is a stereo pair. USB 1 is the left channel while 2 is the right channel. To answer your original question, pan guitar hard left and mic hard right. If guitar goes to USB 1/2 as output, there will be no guitar in USB 2. Quote Link to comment Share on other sites More sharing options...
markblack77 Posted October 26, 2016 Author Share Posted October 26, 2016 USB 1/2 is a stereo pair. USB 1 is the left channel while 2 is the right channel. To answer your original question, pan guitar hard left and mic hard right. If guitar goes to USB 1/2 as output, there will be no guitar in USB 2. cheers for the reply. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted October 27, 2016 Share Posted October 27, 2016 using different USB channels is easier than doing that panning, though. Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted October 30, 2016 Share Posted October 30, 2016 I did some recording with Helix recently and split USB 3/4 by panning two different mono paths left and right and assigning both to USB 3/4.The other two paths were stereo to USB 1/2 and USB 5/6, and also recorded the dry tracks on 7 and 8. Works great! Quote Link to comment Share on other sites More sharing options...
