cavalodeoutubro Posted October 28, 2016 Share Posted October 28, 2016 Hi guys,I was wondering if you could help me with the best configuration of connections for my specific case.I'm keen on buying the POD HD500X and I have an ORANGE CR120h (transistor head with fx loop) connected to a 2x12 Harley Benton Cabinet. I was hoping to use only the POD HD500x with minimal contribuition to the tone from the amp, as close as a it gets comparing with the sound I get when connecting the POD to a DAW. What type of connections should I make? Connect it on the amp's front? Use FX Loop?Thanks in advance Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 28, 2016 Share Posted October 28, 2016 Plug the HD right into the FX return of the head. Watch the volume as it will be full tilt. 1 Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 28, 2016 Share Posted October 28, 2016 Guitar into POD and POD into FX loop,this will bypass you amp's preamp. You can also look into the 4 cable method, it allows you to choose whether or not you want the amp's pream clolor. 1 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 28, 2016 Share Posted October 28, 2016 I was hoping to use only the POD HD500x with minimal contribuition to the tone from the amp, as close as a it gets comparing with the sound I get when connecting the POD to a DAW. I'm not gonna say it's impossible, but it won't be simple either. Monitoring through a DAW with headphones or studio monitors is VERY diffrent than running into an actual guitar amp. The frequency responses are worlds apart, and you can expect to do a great deal of editing of any and all patches that you've been using to record direct. Now this doesn't mean that you can't get good tones with this kind of set-up...plenty of guys do exactly that. Just know what you're getting into ahead of time. 1 Quote Link to comment Share on other sites More sharing options...
cavalodeoutubro Posted October 28, 2016 Author Share Posted October 28, 2016 Thanks a lot all of you! Wonderful community here.That said, and just to clarifiy:Guitar to POD -> POD's FX Send to Amp FX Return and Amp FX Send to POD's FX Return?Is this the most consensual answer?Any typical guitar to amp jack will do for the FX's connections? Also, I'm not gonna say it's impossible, but it won't be simple either. Monitoring through a DAW with headphones or studio monitors is VERY diffrent than running into an actual guitar amp. The frequency responses are worlds apart, and you can expect to do a great deal of editing of any and all patches that you've been using to record direct.Now this doesn't mean that you can't get good tones with this kind of set-up...plenty of guys do exactly that. Just know what you're getting into ahead of time. I'll be aware of that and explore many combinations! Thanks once again, this community and answers alone makes me want to buy the POD asap. Quote Link to comment Share on other sites More sharing options...
cavalodeoutubro Posted October 28, 2016 Author Share Posted October 28, 2016 the most conesensual answer seems to be: Guitar to POD-->POD standard outputs to amp Return Oh, that's precisely what I was trying to clarify! So the typical guitar to amp jack will do just fine? Thanks again Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 28, 2016 Share Posted October 28, 2016 Guitar=>POD Guitar Input=>POD 1/4" (MONO) OUT=>Amp FX Return Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 28, 2016 Share Posted October 28, 2016 for better results maybe (do your experiments) you shouldn't use the full amp (which include power-amp) models but instead the pre-amp only versions, and disable the cab model Great point!! Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 28, 2016 Share Posted October 28, 2016 You know though, I like the full-amp models through a power amp/cab. So at least give them a shot. That Orange head is pretty sweet too btw. 1 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 28, 2016 Share Posted October 28, 2016 You know though, I like the full-amp models through a power amp/cab. So at least give them a shot. That Orange head is pretty sweet too btw. I second this.... I tried the pre-amp only route with a tube power amp and cabinet. It was awful...screech owl having a panic attack awful. No matter what amp model I tried. Full models, studio/direct, and all was right with the world. Quote Link to comment Share on other sites More sharing options...
cavalodeoutubro Posted October 31, 2016 Author Share Posted October 31, 2016 Thanks a lot guys, tons of ways for me to try and figure out my sound!I'll be testing them all that's for sure. Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 31, 2016 Share Posted October 31, 2016 Cool my man, the flexibility and depth of the HD allows for many paths to reach "tone". :D Quote Link to comment Share on other sites More sharing options...
