HD400 DSP Boot Failed Error
moseswebb
PRELUDE:
- The XP computer I was using died.  I had to purchase a new computer.  I no longer have access to that XP computer.
- Unfortunately the new computer is running Windows 10.
- In the process of reloading all software (POD Farm) and drivers, during the firmware update something failed (as others has posted).
- The HD400 will no longer boot up.
FACTORY RESET DOES NOTHING:
- Returning the HD400 to factory reset does nothing for this issue.  Others have tried.  Has nothing to do with the reboot error.
- The inability to boot up clearly has to do with the attempt to update the firmware, which failed during the process.
CAN NO LONGER CONNECT HD400:
- As others have reported, Ling 6 Monkey does not recognize the HD400 as being connected; therefore I cannot reload the firmware, or
  attempt that procedure.
- This is where the issue lies ultimately.  Without a way to communicate with the HD400 and reload SW I am dead in the water.
THE END:
By now Line 6 I hope has some useful feedback to repair this problem and render my boat anchor a useable piece of audio equipment again. From older threads it does not appear that anyone has come up with a fix for this.
Any help greatly appreciated.
  • Downvote 1
DL the flash file to your HD so you can choose "Flash from File".
Safe mode reflash:
Power up while hold "A" down, connect USB fire up L6 Monkey and reflash.
Recalibrate the Exp pedal if that works - I think its hold "D" while powering up.
Reloading all the software must have worked so you had a USB connection for the HD (or you wouldn't have wanted to reflash). so Hopefully things will work.
  • 10 months later...
I have a POD HD400 that froze while trying to update, now I get DSP Boot Failed Error - tried everything listed above but no success, I get an error message on monkey every time after trying for 10-15min  PodHD400 screen says Downloading.... until I unplug it - what can I do? How do you know it's in "safe mode" when re-starting while holding down A? It just says "push presets for factory restore"
  • 2 years later...
  • 1 year later...
  • 5 weeks later...
I'm having the same issue after trying to update my HD400 - DSP Boot Failure. Trying to reset to factory default does not help and I haven't had a response from Line 6 support for a couple of weeks now (I created a support ticket asking for a solution).
  • 2 weeks later...
On 10/13/2019 at 12:52 PM, Jeffsar said:
hey there I was trying to update my pod hd400 and it gave me the same error , after reinstalling the usb frimware and trying to install the firmware from file I think it worked just fine
I cannot connect via usb to the device after the dsp boot failure. Do you recall how you reinstalled the usb firmware?
