No Sound From My Vetta Ii Combo. Where To Start?
22 replies to this topic
#1 kylejt
kylejt
  • 9 posts
Posted 01 September 2013 - 09:14 AM
It's been a bit flaky from my initial purchase. The seller said it might need a common repair down the road, but I was so giddy at getting it, a long board, plus a 2x12 extension cab for $400, my eyes were glazed over.
So, the display looks normal, but no sound from the speaker, nor headphones. I get the initial, normal POP with firing it up. Where should I start? (Yeah, I already swapped out guitars and input cords).
Kyle
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 01 September 2013 - 10:34 AM
so you get a pop when energizing. i would think  the output section is working. is there any noise at all after you turn it on? but with no test equipment and no schematics how can you troubleshoot? i would inject a signal at the input and follow the signal path until it stops but for that you need a sig gen and a spectrum analyzer. otherwise i'm stumped.
I'M SO HAPPY!
#3 kylejt
kylejt
  • 9 posts
Posted 01 September 2013 - 03:48 PM
Is there a common Achillies heel on these amps? Something that routinely fails?
Edit: After reading a few comments, I recall the seller telling me the battery might be suspect. Would that cause the output isssue?
#4 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 01 September 2013 - 04:23 PM
i think the battery is for storage but it may affect output
I'M SO HAPPY!
#5 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
  • Registered Products:2
Posted 03 September 2013 - 09:01 AM
The battery is there to keep the static RAM chip from dumping it's contents. Folks use flash memory for that sort of thing now but yes the back up battery being dead can make all sorts of things do crazy stuff so it's good practice to start there since they are so cheap to change.
After installing a new battery, I'd probably reload the software just to be sure you get a good clean start up.
I assume you've tried several patches and have disconnected the long board to simplify things.
BTW you don't really need a spectrum analyzer to signal trace the amp but a common oscilloscope would sure go a long way towards troubleshooting both the digital and analog stuff. Then again you'd have to be familar with this sort of thing, if not I'm sure you can find a friend who is.
BTW The service manual can be downloaded from the Internet at http://elektrotanya....f/download.html  Ever who digs into it will need it. It's for the head amp but the head and the combo amps are almost identical in large part. Enough to nail your problem anyway.
  • 1
#6 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 03 September 2013 - 10:03 AM
that's what i meant. i don't know why i said specrum analyzer
I'M SO HAPPY!
#7 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 05 September 2013 - 11:49 AM
Spectrum analyzers are nice too. The good thing about doing audio stuff is you can do the spectrum analyzer thing with a PC, a sound card and some free software. Well good enough in a pinch without spending the bucks on the real deal anyway.
#8 kylejt
kylejt
  • 9 posts
Posted 07 September 2013 - 09:36 AM
Well, flashing the memory did the trick. Now it's on to making the long board work. All I get is a quick blink of the LEDs above the pedals, and then nada.
#9 sliding_billy
sliding_billy
    Iknowathingortwo
  • PipPip
  • 141 posts
  • Registered Products:10
Posted 08 September 2013 - 11:13 AM
Have you tries a new cable?
#10 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 08 September 2013 - 03:24 PM
Just so you know if you didn't already, the long board has to be turned on and saved in the on state in each and every patch that you intend to use it in. Just hit the toe switch in each patch that you want the board enabled in then save the patch in that state. It will also save any custom mapping of the expression pedals that you've done. By default the expression pedals are wah and volume.
The default is no board in each and every factory patch and until you turn it on it don't know nuttin until you tell it it's there with it plugged in and then turned on. Yeah I know, it's a PITA but it is what it is.
#11 kylejt
kylejt
  • 9 posts
Posted 13 September 2013 - 08:11 AM
I tried several cables, so that's not it.
lollipop, you said the board has to be "turned on". I'm new to the Vetta world, so I'm not sure what that means. Is there something on the Vetta I need to configure to get the FBV to go hot? Right now, aside from the initial LED blink, it's dead, with no display.
#12 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 14 September 2013 - 10:53 AM
Press the toe switch under the volume pedal. Sometimes you have to press down hard. That turns the board on but you have to save it on in each patch that you want to use the board in. Try reading the instrustions too. That often helps a lot.
#13 kylejt
kylejt
  • 9 posts
Posted 18 September 2013 - 12:01 PM
Amp went flakey again. No sound output. Front panel looks good. An interesting symptom: when using the Tuner, it won't report the E and A, but will the rest.
Took the rig to the local Line repair place, and they told me it's the second one in their shop with the same problem, and Line 6 wants them to ship to them. Interesting.
#14 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 21 September 2013 - 10:18 AM
Either E? It sure sounds like it almost has to be a digital problem of some kind. Did you get the long board working? How's the tuner display on it?
#15 kylejt
kylejt
  • 9 posts
Posted 21 September 2013 - 10:39 AM
Nope, just low E and A aren't getting through on the tuner.
The longboard is DOA. I opened it up, and the all the ribbon cables were disconnected. Someone cooked it, tried to fix it, and it didn't work. It's a gonner. My repair shop will take it, and the case, and give me a nice credit toward the repair. Luckily, I only paid about $30 bucks for it, and took a chance. In the end, I still made out, but will look for another down the road.
#16 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 24 September 2013 - 11:11 AM
That's too bad. The long board is a great addition to the Vetta. It's a well built piece too.
I found a used one at Guitar Center for not much and lucky for me it worked just fine. I've adapeted mine with a couple of bits of wood so it fits and parks right into the back opening of my Vetta combo for transport and storage.
#17 lally
lally
  • 3 posts
  • Registered Products:3
Posted 18 January 2014 - 04:55 AM
MY vetta 2 was working fine but now I have no output from the speakers at all....there is a 'pop' when i start it up and i can tune the guitar via the tuner I've had a look inside the longboard and it all looks connected I've also gone through the output and that is all on speaker too........it's obviously getting the signal from the guitar but nada from the speakers.........and yes i've checked those too......any ideas?
#18 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 18 January 2014 - 11:05 AM
Can you hear anything with a set of headphones plugged in?
Careful with headphones plugged in the speakers are automatically muted so there could be something amiss in that circuit. It gets the power amp mute signal via a mechanical connection in the head phone jack so if that has gone flakey then the speakers will be muted.
It's somewhere to start anyway.
#19 lally
lally
  • 3 posts
Posted 19 January 2014 - 07:04 AM
Hiya DickFoster.....yeah the headphones output works fine......the amp was also working when i used the output on the back straight into the pa....so i'm thinking that if it was muted then that would also apply to that circuit too...but thanks for that
#20 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 20 January 2014 - 11:04 AM
Actually no. The only thing that mutes with the heaphones plugged in is the preamp to the power amp that drives the speakers. All the other outputs headphone output, effects out and direct out will still function with the headphones plugged in. That tells us that your problem is likely either with the preamp, power amp or one of the supply voltages dedicated soley to one of those circuits.
At least that piece of info eliminates a whole bunch of stuff in the front end of the amp, the DSPs, processor, etc. etc. etc.
It's all about finding out what works and what doesn't so you know where to start looking for the problem. In electronics they call this the half split method of troubleshooting. You start in the middle of the overall circuit to find out if the first or second half is good or bad then cut the known bad half into half again etc. until you eventually get the problem isolated down to your problem component.
Now that you know that the front half is good, ever who works on it need only look at the back half to find your problem.
The fact that it's a stereo amp and both channels are not working should make it just that much easier to find the trouble. Armed with a schematic and common test gear like a DVM and scope ever who your tech is should have little trouble finding your problem and getting it put right again.
#21 lally
lally
  • 3 posts
Posted 21 January 2014 - 10:44 AM
it's official.........it was the power amp module which burnt out..............I originally bought the amp from GAK in Brighton as 'B' stock and was assured by the salesman(line 6 retailer) that it was brand new and simply did not have the packaging with it,apparently the person who bought it did not like the 'pop' sound when it was turned on,I was told that it was perfectly 'normal'......stupidly I believed him.....now after 2x150 mile round trips (away touring at the weekend so time was a factor) and £157 lighter the amp no longer 'pops' when turned on.......I was informed by a member of their staff at Rugby that I was just 'unlucky' and that there is a bad one in every batch,in saying that I can't praise the guys in the workshop highly enough.....so to summarise.....dodgy amp leaves factory,dodgy amp gets returned to retailer who passes it off as 'perfect' and end user stumps up cash to have it fixed........happy? not really, but I guess that I don't have to go out and hire an amp and some pedals for the tour......thanks for your input though DickFoster
#22 DickFoster
DickFoster
    Iknowathingortwo
  • PipPip
  • 273 posts
Posted 22 January 2014 - 10:08 AM
I'm glad you got it sorted out. Vetta's are good amps with a solid design.
Did they change the whole board or just the bad component parts? As complete boards are getting ever tougher to find, it's making component level repair the only option as time goes forward.
If you know could you share what the defective components were?
#23 Muddhole
Muddhole
  • 10 posts
Posted 20 June 2014 - 08:17 PM
lally said: "it's official........it was the power amp module which burnt out"
