bumblebeemouth Posted September 1, 2013 Share Posted September 1, 2013 I am controlling a line 6 M13 with the Ground Control Pro. Everything is working fine except for the expression pedal. I am using a Roland EV5 expression pedal with the GCP. When I use the expression pedal, the effects on the M13 do not respond in real time, and it can take over a second for the M13 to catch up once I stop using the pedal. If I go into the edit mode on the GCP, I can see the numbers changing in real time as I use the pedal, so there is no lag up to that point anyway. I have controlled the M13 before with the expression pedal on a boss GT-6, and have had absolutely no problems. Any ideas? Quote Link to comment Share on other sites More sharing options...
thewebgear Posted September 9, 2013 Share Posted September 9, 2013 It might be the same problem as the Behringer FCB1010. Check out this response to see if it would help you. http://line6.com/supportarchivenew/thread/49289 Quote Link to comment Share on other sites More sharing options...
