tauzero Posted November 14, 2016 Share Posted November 14, 2016 After some over-enthusiastic button pressing, the power button on my XD-V35 handheld has stuck in.Is there a reliable way to release it without dismantling the mic, and if not, how do I dismantle it to get to the buttons? Quote Link to comment Share on other sites More sharing options...
tauzero Posted December 5, 2016 Author Share Posted December 5, 2016 In case this should prove useful for someone else - I needed a T20 screwdriver (at least 100mm long) and a T10 screwdriver. Remove the battery compartment sleeve and use the T20 screwdriver through the hole in the end of the battery carrier to undo the screw in the centre of the battery carrier base. Carefully lift the battery carrier off and you'll see two T10 screws (you can get to these without disconnecting the wires, just be careful). I undid one, then started undoing the other and the button popped out. Reassembly is the opposite of disassembly, as they say in Haynes manuals. Quote Link to comment Share on other sites More sharing options...
