peterteleman Posted November 15, 2016 Share Posted November 15, 2016 Just picked up a pod hd500x and need to figure out what signal flow to use when using the 4 cable method and effects loop in amp....just getting started and haven't figured this out yet. Doesn't seem like combo front in the set up menu would be correct.... Quote Link to comment Share on other sites More sharing options...
gioter Posted February 23, 2017 Share Posted February 23, 2017 hello there, I've just another question about this method: is it possible to use the pod loop to switch somehow between the pre-amplifier section (so to use the original amp dist.) and the pod amp models? (i.e. a "button" configured with "loop on AND pod amp off" and vice versa). some ideas? thank you much G Quote Link to comment Share on other sites More sharing options...
gioter Posted February 23, 2017 Share Posted February 23, 2017 you can assign the amp model turned off and the FX Loop block turned on to the same footswitch, so by pressing the assigned footswitch you can have: the FX Loop block turned on (connected to your pre-amp) and the amp model bypassed.. or the FX Loop block bypassed (thus also your pre-amp) and the amp model enabled hello there,really thanx alot! didn't know you can use one switch for multiple functions! Giorgio Quote Link to comment Share on other sites More sharing options...
