How Can I Use The Aux Input Pod Hd500x ?
aux input hd 500x separate stereo two guitars
5 replies to this topic
#1 jonjontown
jonjontown
  • 1 posts
  • Registered Products:2
Posted 01 September 2013 - 10:19 PM
is there any way i can separate two guitars one in the aux and one in the guitar input?
Can i separate both guitars into different amps if i am running stereo ?
like having aux input into left amp and guitar input into right
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16055 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 02 September 2013 - 05:01 AM
Yes you can do this. Here is  a similar preset designed for acoustic guitar and mic:
http://line6.com/cus...one/tone/215659
You will need to edit the above preset to:
- adjust the Inputs (change Mic to Aux)
- adjust the amp/FX processing in each channel as desired
- use the HD500x Mixer to pan the channels fully left and right, and
- route the appropriate L/R channel outputs of the HD500x to your outboard equipment.
.... John Lennon
#3 jclonin7
jclonin7
  • 1 posts
Posted 06 January 2014 - 02:01 PM
If you do as jonjontown recommended, will the two inputs (A and B, guitar and aux) run through different amps?  I would like guitar to run through one amp and pedals, and aux to run through another set of pedals and amps.
Thanks,
jclonin7
#4 charlesguild
charlesguild
  • 1 posts
Posted 09 October 2015 - 06:12 PM
Thanks guys. That post was really helpfully.
#5 pfsmith0
pfsmith0
    Gear Head
  • PipPipPip
  • 616 posts
Posted 10 October 2015 - 06:35 AM
jc, yes you can run Guitar -> Input 1 -> Channel A -> amp A and Aux -> Input 2 -> Channel B -> Amp B. You can even run the mixer so that Amp A -> right channel and Amp B -> left channel so the sound guy can have two feeds with different gain, EQ, etc.Basically you'll have 2 separate mono channels isolated from each other. If the search function works in this forum, search for dual amp tones and you'll see how to do some this.
#6 maestoso
maestoso
  • 1 posts
Posted 20 November 2016 - 05:06 AM
I don't know if this is been said before but I just figured out if you take an acoustic guitar and go through the mic input like adapt an XLR down to a stereo TRS adapter oh my God you get perfect acoustic guitar tones play with your on-board EQ a little bit but man it's perfection I hope this helps anybody that struggles with this
Also tagged with one or more of these keywords: aux, input, hd 500x, separate, stereo, two, guitars
