Wyattburp86 Posted November 22, 2016 Share Posted November 22, 2016 Hi all, Can you use the Line 6 Helix multi-effects board easily with a tube amp? I'd like to consider using it with no amp modeling and only use the effects to adjust the clean tone from the amp. Also, can the expression pedal be configured to control the master volume of your signal similar to a standalone volume pedal (e.g. Ernie Ball), even if the amp modeling is turned off? The goal would be to use the Helix's effects in lieu of a massive pedal board and use the built in volume pedal for volume control and swells. Thanks for the feedback! Best, WyattBurp86 Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted November 22, 2016 Share Posted November 22, 2016 Yes, yes, and yes. We designed Helix to seamlessly fit into your workflow, not shoehorn you into its workflow. Quote Link to comment Share on other sites More sharing options...
seattleguitarist Posted November 24, 2016 Share Posted November 24, 2016 Works great other than the lack of midi clock. Quote Link to comment Share on other sites More sharing options...
drspankle Posted November 24, 2016 Share Posted November 24, 2016 I'm using it with a Marshall JTM and it sounds great. That said, I do wonder what it would sound like through an FRFR cab, as there is always bound to be a bit of amp colouring to the tone from the Marshall. Regards, Dr Spankle Quote Link to comment Share on other sites More sharing options...
Wyattburp86 Posted December 4, 2016 Author Share Posted December 4, 2016 Thanks for the insights. I settled on a Pod HD500x and just finished my first patch for it. been happy with it so far! Quote Link to comment Share on other sites More sharing options...
sheehanje Posted December 4, 2016 Share Posted December 4, 2016 I'm using it with a Marshall JTM and it sounds great. That said, I do wonder what it would sound like through an FRFR cab, as there is always bound to be a bit of amp colouring to the tone from the Marshall. Regards, Dr Spankle Sounds GREAT through FRFR. Finally pulled the trigger on a pair of L3T's. I have a Mesa Boogie JP-2C that is now collecting dust. Quote Link to comment Share on other sites More sharing options...
roscoe5 Posted December 4, 2016 Share Posted December 4, 2016 Sounds GREAT through FRFR. Finally pulled the trigger on a pair of L3T's. I have a Mesa Boogie JP-2C that is now collecting dust. Whoa...bold statement sir :). My Mark V is sitting unused as well, although I've yet to go FRFR. At least you've got a great amp in the stable if/when line 6 releases amp matching. Quote Link to comment Share on other sites More sharing options...
sheehanje Posted December 4, 2016 Share Posted December 4, 2016 Whoa...bold statement sir :). My Mark V is sitting unused as well, although I've yet to go FRFR. At least you've got a great amp in the stable if/when line 6 releases amp matching. I think I spoke too soon, lol. Just rehearsed with the band today and it was really hard getting my patches to sit in the mix well. I know it's just a matter of adjustments - especially low cut seeing it was sounding pretty flubby. The one plus is it sounded and felt like a real amp - just not as good as the JP-2C yet... Quote Link to comment Share on other sites More sharing options...
