Reaper Says "no Asio Drivers Found!"
reaper hd500 recording drivers
21 replies to this topic
#1 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
  • Registered Products:3
Posted 02 September 2013 - 04:34 PM
So I've been using Reaper forever with various versions and up until today, I've had no problems. Now I load a project I was working on yesterday and when I try to select the POD HD500 driver in the dropdown it says "No ASIO Drivers Found!" and shows no I/O selection options.
I already uninstalled/removed from registry/reinstalled Line 6 Drivers via Monkey and direct download
I have uninstalled all other ASIO device drivers (TASCAM US-1800, AudioBox 2x2)
Tried installing ASIO4All---still doesn't show up
Uninstalled/reinstalled Reaper (tried with old versions and the newest)
Still get the "No ASIO Drivers Found!" message
Anyone have any other ideas? I'm not really looking forward to reinstalling my whole OS and all my plugins to get Reaper to work. I can use Cubase LE, WaveLab, or Studio One Artist with the drivers no problem (including ASIO4ALL).
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9243 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 02 September 2013 - 05:24 PM
Does the HD500 show up as an audio device in your Device Manager?
  • 1
#3 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 02 September 2013 - 08:56 PM
yep, every other function is working, I can open the driver dialogue and change settings from Control Panel, driver and device show up in other audio programs. It's even still working as the output device for Foobar2000 (freeware media player).
#4 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
Posted 03 September 2013 - 04:40 AM
In no particular order and some of which you may of done aldready
check usb drivers might be corrupted on the record.
Also, unhinge it from the audio player if possible.
open pc "sounds" utility in  control panel and select it in there.
Reinstall asio4all.
  • 1
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 03 September 2013 - 05:02 AM
Just for clarification, if you run Monkey you have green ticks for everything?
If you create a new project in Reaper do you get the same symptom?
  • 1
#6 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 03 September 2013 - 06:16 AM
Reinstall asio4all.
I redid my USB drivers for the computer, removed old from registry, but this seems unneeded as it works in every other audio program like Cubase LE, Wavelab, etc....reset Foobar2000 drivers to WDM when it started, and I've done two un/installs of ASIO4All in the last 24 hours....thanks, though!
Yes, and Yes. I even went as far as deleting all my user preferences and initiliazation files for Reaper, opening a project with factory defaults restored, ...still no "seeing" my drivers.
Thanks for trying guys!
#7 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 03 September 2013 - 06:28 AM
Do you have a specific need for ASIO4ALL?
I personally would completely remove ASIO4ALL until you resolve the situation.
Also try manually disabling any other audio devices and selecting the POD HD 500 as your default device.
BTW, can POD HD 500 Edit communicate with your POD HD 500?
#8 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 03 September 2013 - 08:55 AM
Yep, Edit works fine, the problem is isolated to Reaper, and I did remove ASIO4All as soon as I saw it wasn't working....I'm not a fan of the driver, but its been useful when similar issues have come up without the time to properly repair things cause it ALWAYS seems to work, which it did in Cubase...
I can set the HD500 to be my main soundcard if I want, but it still doesn't show up in Reaper...getting a little pissed at my g*&d(*&n f$%$ing computer....
#9 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 03 September 2013 - 09:33 AM
Have you contacted the support folks at Reaper?  This sounds like more of a Reaper issue than a Line 6 driver issue.
#10 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 03 September 2013 - 09:34 AM
yep, waiting...
#11 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 03 September 2013 - 09:35 AM
Are you saying in Reaper's preferences, for devices, ASIO POD HD 500 isn't even listed?
#12 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 03 September 2013 - 09:41 AM
Odd . . . Reaper shows my HD500 as an option even when I don't have it attached to my PC.
#13 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 03 September 2013 - 01:22 PM
No ASIO devices are listed at all
Yeah, thats how it usually looks/works for me, too.
#14 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 03 September 2013 - 01:33 PM
Have you tried uninstalling and reinstalling Reaper? Even though Reaper will most likely detect and protect project files during the uninstall/reinstall, I would make a backup copy in advance anyway.
.... John Lennon
#15 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 04 September 2013 - 05:30 AM
I did uninstall/reinstall reaper several times now...the driver is hidden from it for some reason
#16 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
Posted 04 September 2013 - 06:20 AM
So it seems to be a reaper only issue, including any previous version. weird alright.
google this; Foobar2000 drivers
There are a tone of asio issues which might resolve it
Also WDM isn't asio and so it won't show. Can you select asio instead?
Does the tascam show up?
#17 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 04 September 2013 - 07:26 AM
don't have the TASCAM at home, unfortunately.
#18 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 05 September 2013 - 07:27 AM
So Reaper support forums are giving me nothing, the problem still persists...I've rolled drivers back (like a year and half back!), went all the way back to Reaper 3.2.....still not working. And, everything still works just wonderful in every other program on my PC that can use ASIO drivers in any of the versions/configurations I've installed....WTF! Guess I'll spend some more money and buy the Pro version of Studio One...
#19 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 05 September 2013 - 07:43 AM
I'm assuming that you've paid for a Reaper license.  I'm not sure how to get hold of them by phone, but if you haven't already, you should send an email to support@cockos.com
#20 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 05 September 2013 - 08:23 AM
sent
#21 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 06 September 2013 - 09:47 AM
So, the guys at Cockos think I need to DE-select "Microsoft Wavetable GS Synth" in the midi devices panel...haven't tested, but that was the "official" suggestion
#22 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1103 posts
Posted 09 September 2013 - 07:07 AM
This had no effect on anything....I've uninstalled/deleted from registry/reinstalled drivers, done the same with Reaper (tried different locations, portable install to HDD, portable install to thumb drive, installation on a different partition) and the problem persists, but again, only in Reaper. Got my Studio One License on Saturday and have been working on bouncing out all of Reaper projects and moving them over (reaper still works with Windows native drivers for some reason!?!?! just not any of my interfaces or ASIO4ALL) If you guys think of something else, please let me know, as I'm not fully ready to give up on Reaper just yet, but thanks for all of the suggestions so far.
Also tagged with one or more of these keywords: reaper, hd500, recording, drivers
