singlecut69 Posted September 3, 2013 Share Posted September 3, 2013 I'm wondering if there are some best practices for using the looper for patch tweaking, or if it's even possible. Quote Link to comment Share on other sites More sharing options...
GTLazer Posted September 3, 2013 Share Posted September 3, 2013 Put the looper in the 'pre' position. That's about it, really. 1 Quote Link to comment Share on other sites More sharing options...
parkinthepark Posted September 6, 2013 Share Posted September 6, 2013 This is probably the best way to tweak your patches, because you can focus on what you're hearing, not what you're playing. Always put the looper in "Pre" mode Make sure that your looper playback is set to full, especially when dealing with amps, compressors, and distortions. Make sure your loop has a good mix of high and low, loud and soft notes. Remember to switch out of looper mode (playback will continue) when you want to hit your footswitches. Remember to save your changes before moving to a new patch. Quote Link to comment Share on other sites More sharing options...
