archo Posted November 27, 2016 Share Posted November 27, 2016 Hey,how do you set your patches while using 4cm? Where you have gates, mixer,eq and so on. Thanks. Quote Link to comment Share on other sites More sharing options...
archo Posted November 27, 2016 Author Share Posted November 27, 2016 I know that, but I am interested in what you guys personally use. Quote Link to comment Share on other sites More sharing options...
J_V_RO Posted November 28, 2016 Share Posted November 28, 2016 I know that, but I am interested in what you guys personally use. I use the 4CM. My chain usually goes like this: Gate > Comp > Wah > Modulation> Dist/OD > EQ > AMP > FX LOOP > Delay > Reverb Quote Link to comment Share on other sites More sharing options...
archo Posted November 28, 2016 Author Share Posted November 28, 2016 I use the 4CM. My chain usually goes like this: Gate > Comp > Wah > Modulation> Dist/OD > EQ > AMP > FX LOOP > Delay > Reverb Hey, you use a real AMP? Do you use Dist/OD and Comp even if that amp is in lead channel and if yes which one of thous you choose and how do you set them. thx so far Quote Link to comment Share on other sites More sharing options...
J_V_RO Posted November 28, 2016 Share Posted November 28, 2016 Hey, you use a real AMP? Do you use Dist/OD and Comp even if that amp is in lead channel and if yes which one of thous you choose and how do you set them. thx so far I use the modeled amps on the POD. Sometimes I make a "Mix" between the modeled amps and my Marshall AMP 100w. (leaving the FX LOOP block switched on) When the amp is in lead channel I don't use full distortions, I tend to use stompboxes just to color the amp tone a little, for example a screamer with a little gain only and the output leveled... sometimes I just place an EQ in front of the AMP to alter some frequencies.The combination of all this is what makes your sound interesting. This is just my preference, you should find what's better for you. Quote Link to comment Share on other sites More sharing options...
archo Posted November 28, 2016 Author Share Posted November 28, 2016 I use the modeled amps on the POD. Sometimes I make a "Mix" between the modeled amps and my Marshall AMP 100w. (leaving the FX LOOP block switched on) When the amp is in lead channel I don't use full distortions, I tend to use stompboxes just to color the amp's tone a little, for example a screamer with a little gain only and the output leveled... sometimes I just place an EQ in front of the AMP to alter some frequencies.The combination of all this is what makes your sound interesting. This is just my preference, you should find what's better for you. Sounds intresting. I use the POD as Effectboard for my Engl Gigmaster. Actually I'm not EQing ist because the Engls EQ ist extrem precious. In the moment I use that chain. Sustainer (to boost the Preamp) -> FX Loop -> Volume Pedal (at 80% for Lead/Rythms 100 for Solo) -> Modulations -> Delay -> Reverb -> Studio EQ( Gain +4 for Solo Boost) Quote Link to comment Share on other sites More sharing options...
J_V_RO Posted November 28, 2016 Share Posted November 28, 2016 Sounds intresting. I use the POD as Effectboard for my Engl Gigmaster. Actually I'm not EQing ist because the Engls EQ ist extrem precious. In the moment I use that chain. Sustainer (to boost the Preamp) -> FX Loop -> Volume Pedal (at 80% for Lead/Rythms 100 for Solo) -> Modulations -> Delay -> Reverb -> Studio EQ( Gain +4 for Solo Boost) Nice amp man...! yeah, there is a lot that you can do using this method...be careful of not falling in the "trap" of trying to improve your tone every time you play, sometimes is better to enjoy and have some fun with your best patch Quote Link to comment Share on other sites More sharing options...
archo Posted November 28, 2016 Author Share Posted November 28, 2016 Nice amp man...! yeah, there is a lot that you can do using this method...be careful of not falling in the "trap" of trying to improve your tone every time you play, sometimes is better to enjoy and have some fun with your best patch In the Moment I'm pretty satisfied with my tone. I've more the problem to become well sorted. Espacially to work with the latency between patches is a problem. Quote Link to comment Share on other sites More sharing options...
