Good Iidea To Feed Pod Hd Output Into Spider's Line Input?
hd pod spider line input cd mp3
Best Answer greghall , 03 September 2013 - 03:14 AM
I had a Spider Jam for a while, and found that plugging the POD into the CD/MP3 input with the POD in Studio Direct mode sounded best with that amp. You are basically bypassing the amp modelling in the amp and just using the POD that way.
Some of the later Spider amps have a way to disable the amp modelling when you power on the amp, so you can plug the POD into the amp input, but I can't remember how.
Go to the full post
3 replies to this topic
#1 superbrown
superbrown
  • 7 posts
  • Registered Products:1
Posted 02 September 2013 - 09:39 PM
I play guitar at home as a hohby. I have an old Spider III 30 watt amp and am looking at options for upgrading my sound.
Would there be any drawbacks (such as fidelity) to feeding the output of a POD HD into the line input (CD/MP3) in the front of my Spider, which I assume is designed to be uncolored, which is what I'd want? Has anyone tried this? Any thoughts?
#2 greghall
greghall
    Iknowathingortwo
  • PipPip
  • 190 posts
  • Registered Products:4
Posted 03 September 2013 - 03:14 AM   Best Answer
  • 1
#3 moogary
moogary
  • 82 posts
  • LocationToronto, ON, Canada
Posted 03 September 2013 - 03:38 AM
You can hold the TAP button depressed while turning on the amp
  • 1
#4 superbrown
superbrown
  • 7 posts
Posted 06 September 2013 - 11:18 AM
As a follow-up question, if you do run the POD directly into a Spider with its modeling disabled, can you get any benefit from using the cabinet emulators, or are they pretty useless in that scenario? (I realize they're intended for a flat response amp.)
Also tagged with one or more of these keywords: hd pod, spider, line input, cd mp3
