You tube jam track playback No Audio
drjeff007
I have no problem syncing up Spider to my Android tablet but...
I can't get Youtube video jam tracks to produce sound.
It's weird as it was working awhile ago but...
Tried many times and won't produce audio anymore. If I disconnect the
cable then the sound comes out fine from the tablet.
Any ideas would be most appreciated!
  • 2 weeks later...
I can think of a few things to check:
a) Are you using an OTG adapter? iPhone/iPad can connect directly, but Android needs the OTG adapter in order to connect correctly.
b) Did you check the switch on the back of the amp? It should point to Mac/PC/Android, not to iPhone/iPad.
c) Also, some Android devices have a pull down menu with a notification for the connected USB device. Check that it is set to USB Audio (or whatever equivalent option you have on your device), not to "charging".
