Bug Workbench Please Help
6 replies to this topic
#1 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
  • Registered Products:2
Posted 03 September 2013 - 06:50 AM
often have received this message when I try to make a WB Operating, anyone know why this happens?
"failed to write data to the guitar"
and the sound of that model I'm changing mutes ., and now I can not get sound to come back in position 5 of the spank, the workbench repeats this error message
Now, Several models are dumb and a strange writing on the workbench
Jtv 69 , pod hd 500x, suhr S3,, Gibson SG standard 96, fender plus strat 93, les paul custom 96
#2 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
Posted 03 September 2013 - 04:09 PM
That sounds like a USB communication issue of some sort.  What computer are you using to run WB?  Do you have the Variax interface box plugged into the computer directly, or through a hub?
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#3 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 03 September 2013 - 05:46 PM
My pc winows7 and interface usb of line6
#4 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
Posted 04 September 2013 - 04:00 AM
Do you have the interface plugged directly into a motherboard USB port?  Sometimes the ones on the front of the case don't supply enough current.  Worse, I have seen cases where the motherboard USB ports do not supply enough current for certain devices.  My Tascam guitar trainer will not stay connected unless it's plugged into an external USB hub with its own power supply.  This is why standards are so valuable:  Everyone gets to have their own!
If the motherboard ports aren't working, see if you can buy or borrow a hub with its own "wall wart" power supply and give that a try.
#5 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 04 September 2013 - 07:29 AM
strangely the problem stopped suddenly, i really do not know what happened, but thanks for the help
#6 johnnyayyy
johnnyayyy
    Power User
  • PipPipPipPip
  • 1377 posts
Posted 04 September 2013 - 01:08 PM
I had this problem using Windows XP, Dell 1500 and interface plugged directly into motherboard USB. I only experienced the muted positions when I tried changing body types, can't remember if it was okay after unplugging my JTV or if I had to reinstall firmware (it was when the update was released and I reinstalled the firmware around a dozen times over two days so I don't recall the exact order of things, have not worked with workbench since). 2.0=kinda buggy
#7 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 10 September 2013 - 02:34 PM
thanks for all, 2.0 has actually been a problem, seems full of bugs
