M5 Rack Question
Best Answer phil_m , 03 September 2013 - 01:10 PM
It behaves the way you want it to. If you power it off with an effect engaged, it will be the way you left it when you power it back up again.
Go to the full post
1 reply to this topic
#1 gsperry
gsperry
  • 22 posts
  • LocationSacramento, CA
  • Registered Products:1
Posted 03 September 2013 - 01:05 PM
I am about ready to buy one of these. I will put it in my rack pedal tray and switch it in and out with a RJM. My question is, will it work like a normal stompbox? When power is applied, I need it to power on and have the most recently saved effect engaged? I don't care if this is default behavior as long as I can get it set up like that. This way I can set it for a particular function I need, put it on my rack pedal tray and then forget about it until I need to change it. I do not want to have to worry about setting up MIDI to engage it. I will just switch it in and out with a RJM switcher.
If this is not available by default is there a way to sysex or monkey a "Rack Mode" into this device?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9048 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 03 September 2013 - 01:10 PM   Best Answer
  • 1
