9v to micro USB adapter for G10
AlexKenivel
Interesting find! Certainly inexpensive enough.
Although this may make the physical connections, there is no indication of any voltage reduction to stepdown/ reduce the voltage from a typical barrel type pedal power supply's 9v (or higher) to that of a typical USB port's voltage of 5v, (1Ah-2.4Ah). Moroever, the brief product description states : "Can plug into any 5VDC source having a 5.5x2.1mm barrel plug...."
If your power source has an adjustable power setting, reduce it's output voltage to as close to 5v as possible. Otherwise, you may overload the G10's base unit.
Post back if it works! Hope fully it will.
