Diablo1 Posted December 20, 2016 Share Posted December 20, 2016 I got my hd 500x setup to two amps coming from the unbalanced, I want to set up a dual set up coming out of the hd 500x, dual meaning I want one delay effect going to my amp and another delay effect going to the other amp each delay with different milliseconds, how do I set that up in the hd 500x, I know two set up two amp in the signal chain of the 500x then after that I have line a and be where I add my delay pedals to each line, I know what I have to do in theory but how do I do it on the 500x? Is there a link or video for this particular setup Thsnks Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 20, 2016 Share Posted December 20, 2016 For each path you can set the panning for the effects and amps. Fire up HD Edit and also go to the mixer page to make sure the amps are panned. Hard right, hard left. Quote Link to comment Share on other sites More sharing options...
Diablo1 Posted December 20, 2016 Author Share Posted December 20, 2016 Since I wanna go thru my own amps I'm hooked up to, so the preamps or amp I pick should I turn them off on the hd500x so I don't hear them, and hear my amps and if I turn the amp off in the 500x will the delays still work as long I I keep the delays on Thanks Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 20, 2016 Share Posted December 20, 2016 Whoa slow down my man you just confused the lollipop out of me. I was under the impression you were looking to run the HD into 2 power amps (or FX loops). Are you talking about trying to run a twin 4CM? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted December 20, 2016 Share Posted December 20, 2016 Yes, this can be confusing. Please use words like virtual and physical. It makes things easier to understand. Also, because of the subject matter, if you could talk a little bit more indepth about what you want and are trying to do. Stereo and dual and amps and etc... they mean so much different things depending on what we are talking about. Quote Link to comment Share on other sites More sharing options...
Diablo1 Posted December 20, 2016 Author Share Posted December 20, 2016 Is there a mono and stereo fx's? When I added an fx chain on one side of the amp it was all static when I moved it to the other side it worked , is that normal or was something set up wrong Quote Link to comment Share on other sites More sharing options...
Diablo1 Posted December 20, 2016 Author Share Posted December 20, 2016 How do I delete effects in the software I put the cursor over the stomp box and the downward arrow show above but I tried everything to make it pull down with other voices but it doesn't What mixer do I use, in my mixer section on the software I have main mix with path a and path b, so if I use one path I can't use that . The other is variable and l6 line, how do I delete them and pick the right on in the software Quote Link to comment Share on other sites More sharing options...
Diablo1 Posted December 21, 2016 Author Share Posted December 21, 2016 The static noise on the path seems to come from in dynamics I tried the red comp. seems to be a circular hum, if I turn number 4 to 100 percent it gets worse, is that suppose to be there or do I need a noise suppressor, I tried my compressor sustain pedal on the fx loop it's even worse Quote Link to comment Share on other sites More sharing options...
