randyNH Posted January 12, 2017 Share Posted January 12, 2017 I recently bought an Audient ID14. I would like to use this as my main interface, but I would like to still use the POD at times for certain tones. What is the ideal way to connect the POD to the new interface? Do I connect 1/4" cables from outputs of the POD to the inputs of new interface? Quote Link to comment Share on other sites More sharing options...
cclement Posted January 13, 2017 Share Posted January 13, 2017 yes.. ..or you can use the digital/optical connection to avoid an additional DAD conversion Unfortunately it looks like the Audient ID14 only has a Optical for it's digital IN. So you will need to SPDIF to Optical (AKA Toslink) convert if you want to go digital OUT from the HD500X. There are a bunch out there and many aren't that expensive: https://www.amazon.com/Signal-Converters/b/ref=dp_bc_5?ie=UTF8&node=306896011 1 Quote Link to comment Share on other sites More sharing options...
