Tap/tuner Button Misfiring
tap tempo tuner misfire double contact
Best Answer PaulJam , 07 September 2013 - 04:44 PM
I had the same problem with my HD500. It was a hardware issue. I had to solder in a new switch and now everything works fine again.
Go to the full post
6 replies to this topic
#1 undeceived
undeceived
  • 3 posts
  • Registered Products:3
Posted 06 September 2013 - 11:42 PM
Hey, everyone.  I've had an HD500 for about a year and a half and recently the tap/tuner button started misfiring.  What I mean is that sometimes when I press it once, it registers as two times, making the tempo insanely fast.  Also sometimes when I hold it down and it goes to tuner, it will register contact, when I release it, so then it exits tuner mode.  Is there anything I can try to do before sending it in for repair?  Any ideas would be appreciated.
#2 matthewterrado
matthewterrado
  • 21 posts
Posted 07 September 2013 - 07:53 AM
I've had two HD500s do the same thing to me and they both needed a new tac switch. I tried resetting the firmware and everything but it was a hardware issue. I ended up using an external tuner so I wouldn't use the tap/tuner button so often.
  • 1
#3 PaulJam
PaulJam
  • 68 posts
Posted 07 September 2013 - 04:44 PM   Best Answer
  • 1
#4 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1200 posts
  • Registered Products:2
Posted 07 September 2013 - 09:23 PM
Where you get the switch from just in case I have to change mine one day? I am hoping an electronics store off the shelf switch is all that is needed.
#5 PaulJam
PaulJam
  • 68 posts
Posted 08 September 2013 - 07:25 AM
I got mine from a local electronics store. The switches are similar* to this one:
http://www.conrad.de...01A-Drucktaster
*This one is a little bit taller than the original. (Works, but only if you remove the plastic part between the spring and the switch)
  • 1
#6 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1200 posts
Posted 09 September 2013 - 04:24 AM
Thank you very much for that. Info like this should remain a sticky
#7 undeceived
undeceived
  • 3 posts
Posted 10 September 2013 - 12:30 PM
Thanks for all the replies, everyone!  The I uses the tap for tempo quite a bit, so I definitely need to get this resolved.  I just noticed that the other bottom buttons have the same problem.  It doesn't matter much when switching patches, but if I use the looper, it can cause some problems.  I'm thinking it may be the bottom circuitboard, so it looks like I'll have to send it in for repairs.
Also tagged with one or more of these keywords: tap, tempo, tuner, misfire, double, contact
