I'm From Russia ,help Please
pod hd500
6 replies to this topic
#1 bit70
bit70
  • 3 posts
Posted 07 September 2013 - 10:10 AM
Need urgently scheme on POD HD500, service centers I have in Russia there! Fired from the USB port, the voltage drop!
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 07 September 2013 - 02:53 PM
no elctronic schematics available to the public
I'M SO HAPPY!
#3 bit70
bit70
  • 3 posts
Posted 07 September 2013 - 09:14 PM
I probably left throw my POD HD500! I have not had time to enjoy the sound of this device, and probably for a long time now have to collect new! Without at least without a piece of schemes regarding tract USB and tract power none of the masters, do not want!
#4 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
  • Registered Products:2
Posted 07 September 2013 - 09:15 PM
I've heard the usb connection can get damaged (comes off  the PC board)
You might be able to resolder it back in place.
#5 bit70
bit70
  • 3 posts
Posted 08 September 2013 - 02:12 AM
In it a short-circuit on 3.3 and 1.8 volts in the path of the power supply! Burned chip USB driver
CY7C68013A-56PVXC SSOP56. but this is not the problems I had already shot !! the problem in the cascade is responsible for power circuits and need scheme!!
#6 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
Posted 09 September 2013 - 04:08 AM
I had my friend translate Мне наверно осталось выкинуть мой POD HD500! Я не успел насладится звуком этого апарата, и теперь наверно долго придётся собирать на новый! Без хотя бы без куска схемы касающейся тракта USB и тракта питания ни кто из мастеров, делать не хотят!
But you have translated it above.
It will take you a long time to save for a new one.
If you can fix USB you can use it to record.
Is it the USB or power supply?
Does POD HD 500 work using headphones?
#7 kahnrus
kahnrus
  • 1 posts
Posted 09 September 2013 - 05:02 AM
Try to ask this man: https://vk.com/id8397765 It seems to me that he had same problem. Also you can find many answers on russian forum http://forum.guitarp...?topic=171783.0
Also tagged with one or more of these keywords: pod hd500
