CraigGT Posted January 23, 2017 Share Posted January 23, 2017 The L6 LINK Connectivity Guide for POD HD & DT Amplifiers v2.10 clearly states that, • The MASTER VOLUME controls are not synced between POD HD or any connected DT amps. The POD HD Master Volume also has no effect on the signal fed to the DT amp. Simply use the DT amp Master Volume knob on each amp to control its volume. Well my pod master volume is working so is that something that changed between the HD500 and X versions because the guide only refers to the HD500 or have I got something wrong? I also thought that Mic modelling was turned off when using the link? I don't have the option of 'None' in DT Edit. Thanks in advance Craig Quote Link to comment Share on other sites More sharing options...
jeremybnz Posted February 3, 2017 Share Posted February 3, 2017 I use a stagesource L2T via L6 Link and yep the master works with that too, when I had the HD500 running into a power amp and speaker it worked too... Quote Link to comment Share on other sites More sharing options...
moogary Posted February 3, 2017 Share Posted February 3, 2017 I believe that the Master volume was synced in DT 2.0 of the firmware. See the latest DT Manual Quote Link to comment Share on other sites More sharing options...
