dalewatts Posted January 24, 2017 Share Posted January 24, 2017 I need to figure out how to keep my distortion on full, when volumn pedal is not fully down. When I raise the pedal, the tone becomes clean,,, Quote Link to comment Share on other sites More sharing options...
BillBee Posted January 24, 2017 Share Posted January 24, 2017 Assign the expression pedal to something other then the gain on the amp. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 24, 2017 Share Posted January 24, 2017 First, let's make sure you understand - it is not a volume pedal. Nor is it a wah pedal. It is an expression pedal. It is capable of controlling any effect. **my mistake. while correct for some models, it is not correct on every model. The OP did not say which model he has. I have two suggestions: 1. Don't assign distortion to the expression pedal. 2. Put the volume pedal AFTER the amp. That will keep the "tone" while adjusting volume. 1 Quote Link to comment Share on other sites More sharing options...
BillBee Posted January 24, 2017 Share Posted January 24, 2017 If its not a patch you built a common slot saver was to assign the exp pedal to the vol on the amp model. So fire up L6 Edit and take a peek at what you have. It's not a volume pedal but it could be :) Quote Link to comment Share on other sites More sharing options...
