M13 And Rig Set Up
2 replies to this topic
#1 thewebgear
thewebgear
  • 6 posts
  • Registered Products:1
Posted 08 September 2013 - 06:32 PM
I am looking for advice to set up a rig.  I have the following pieces of equipment and would like ideas to make it work.
Mesa dual rec
Voodoo Labs
Line 6 M13 (4 cable system) w/external pedal
Morley Wah
Pitch black tuner
What I am looking for is midi control over the Mesa channels with the M13.  Do I need to get a midi interface between the voodoo Labs switcher or a Line 6 control board to change scenes and amp channels?  Can I set the Voodoo Labs switch to pick up the scene changes from the M13?
I have research this all weekend and even seen posts with people that can do this with amps that have midi onboard.  What should I get to make this all work?
Thank you,
#2 thewebgear
thewebgear
  • 6 posts
Posted 09 September 2013 - 09:09 PM
I figure how to get the M13 to send the signal to the Voodoo Control Switcher attached to my Mesa dual rec.  There are no posts that I found the show how to do this with out a midi onboard amp.  I talked to the line 6 support line and got great insight to make my set up awesome.   There is a slight delay because the amp switches faster than the effect.  You can control this with the timing of your switching so you don't get the raw amp burst before the effects can kick over.  Overall I am extremely happy with the set up!
Set the M13 midi setting on Omni in scene set up mode (it is a global effect)
Change the Voodoo Switcher to accept CC and PC midi
(unplug power...hold #2 button,,,..plug in power....light flashes)
(Press button #1 and #2.....unplug and the settings are saved)
Plug the Voodoo Switcher back in and your ready for set up
Click on your scene and select the channels on the Voodoo Switcher
Hold #1 and #4 at the same time to save settings to the scene.
Now you have a non midi amp that you can switch channels and boost with your M13.  No more tap dancing......
#3 peewee101
peewee101
  • 10 posts
  • LocationCentral Illinois
Posted 05 November 2015 - 09:52 PM
Are you still using this setup? I am looking at the same setup with Line6 M13 and Mesa Roadster combo. Just wandering if you still like it and what you have learned. :-)
