AbyssJevass Posted February 19, 2017 Share Posted February 19, 2017 Hello, I´ve got a POD X3 Pro together with a FBV Shortboard (this one: http://line6.com/legacy/fbvs)Seemed to work fine so far... BUT, now I´ve got a problem that I didn´t see before, because i didn´t used it until now...If I choose a Channel that has a DUAL-Tone programmed, only Tone1 is loaded and Tone2 stays the same from the Channel usedbefore. I mostly create sounds and send them to the POD X3 on PC via "Gear Box".So if I choose a DUAL Channel there and load it to the POD X3, everything is working fine. But not, if I try to change Channel on the Floorboard.I tried changing INPUTS, PEDAL CONTROL, TWEAK, FOOTSWITCH in "Gear Box" but nothing seems to work.I also tried to change the RJ-45 CAT.5 Cable, but this brought no solution.So... is the first Version of FBV Shortboard compatible to POD X3 DUAL-TONE Channels ??? What can I do so it works ??? or ... would the "FBV Shortboard MKII" bring a solution to that Problem ??? cheerzUwe PS: sorry for my english :-) Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 19, 2017 Share Posted February 19, 2017 Make sure you do not have the Lock Tone 2 feature activated. If so, turn it off. Quote Link to comment Share on other sites More sharing options...
AbyssJevass Posted February 20, 2017 Author Share Posted February 20, 2017 Hi, where can I see/change this ??? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 20, 2017 Share Posted February 20, 2017 I think it's on the home/signal flow screen. There's a little padlock icon in the bottom row of the display - turn the associated knob until the icon shows unlocked. Quote Link to comment Share on other sites More sharing options...
AbyssJevass Posted February 21, 2017 Author Share Posted February 21, 2017 Haha... that´s it !!!Thanks a lot. Quote Link to comment Share on other sites More sharing options...
