brue58ski Posted May 4, 2013 Share Posted May 4, 2013 This is a document I worked awhile on but never quite finished. Though I never completed it I thought it was a shame to put all that work into it and not put it out there. It has to do with how th post FX aren't exactly parallel and why and what the signal path actually is depending on what you do. It was pretty much done but needed a major editing job since it is a bit wordy. You'll see what I mean. Stick with it, it should answer any questions you may have had about the post FX routings. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 4, 2013 Author Share Posted May 4, 2013 OK it didn't take the last post. Here it is. Vetta II Post FX Routing.doc 1 Quote Link to comment Share on other sites More sharing options...
TheWolf2103 Posted May 7, 2013 Share Posted May 7, 2013 This is very interesting brue58ski, Many thanks for taking the time to investigate & uploading the document. I will have a good read through it tonight ... it is a topic which always puzzled me and as a still dedicated Vetta II user with a looper in the FX loop this might be of great interest to me :) Wolf Quote Link to comment Share on other sites More sharing options...
TheWolf2103 Posted May 22, 2013 Share Posted May 22, 2013 Hi brue58ski,Your document solved the problem I had all these years with my looper in the FX loop on patches where I use the expression pedal to blend between 2 amps.On these patches the loop would playback on only one side of the stereo image.Using the FX loop chained after a 'sacrificed' effect block (last 2 pages of your document) solved the problem - it's now playing back 1:1 in the correct stereo image :)Thanks again for uploading this detailed & comprehensive document,Wolf Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 23, 2013 Author Share Posted May 23, 2013 Glad it helped. Hope it will come in useful to others. Quote Link to comment Share on other sites More sharing options...
