The Built-in Limiter In The Stagesource Speakers Preventing Damage
limiter stagesource speakers
7 replies to this topic
#1 jaminjimlp
jaminjimlp
    Gear Head
  • PipPipPip
  • 582 posts
  • LocationGeorgia
  • Registered Products:11
Posted 10 September 2013 - 09:44 PM
The first time that I took my system out and cranked it up I did not realize till later in the gig that the limiters we're staying on quite a bit. I only had my set the  gain at 12 o'clock.
May you be blessed and our Lord Jesus keep you!!!
#2 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 10 September 2013 - 10:08 PM
Is your system an M20d and StageScape speakers? Ae you hooked up via L6 link?
The sensitivity controls on the speakers should be at 12 o'clock. I don't know what you mean by "staying on quite a bit". If that means about equal to quarter note beats with the music that's not too much but it means you'll need more speakers to cover the venue. You could also switch the preset on the outputs t the "punchy PA" setting and get some additional loudness.
#3 jaminjimlp
jaminjimlp
    Gear Head
  • PipPipPip
  • 582 posts
  • LocationGeorgia
Posted 12 September 2013 - 06:23 PM
Yes I have the M20D and the stage source speakers and yes with the beat and it was an outside gig
#4 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 12 September 2013 - 07:58 PM
That's probably not too much ... But you are pretty close to the limit. You may just need more speakers when playing outdoors.
#5 nickinfrance
nickinfrance
  • 66 posts
Posted 19 September 2013 - 10:55 AM
I managed to induce some squealing feedback on my system the other night. It was completely my fault, I dangled a microphone right in front of a stage monitor (l2m). I know feed back is not great for speakers but it got me thinking whether with all L6 components connected, is it still possible to damage the speakers if one is not careful? Or is there sufficient protection in there to not worry about it? All the limiters on the speakers are set to 12.
#6 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
Posted 19 September 2013 - 11:58 AM
Hey Nick
Limiters are set to give a reasonable amount of protection to most things that you could throw at a speaker.  But it is not a 100% guarantee.  It is possible to do this ... but you would have to throw away a significant amount of the capabilities of your system.  Most wouldn't want want to pay for performance and then only get to use 25% of it .
That said I wouldnt worry much over it.  Especially when you use the entire system via L6 link.  There's an incredible amount of protection well above the normal of other systems when you use L6 link.  When you combine that with the mixer's ability to ward off potential problems I wouldn't expect problems when using the system as a typical music system.
Don't let it get hit by a lightning bolt, or in the middle of the Sahara during summer or at the North Pole during a blizzard. ;)
#7 nickinfrance
nickinfrance
  • 66 posts
Posted 19 September 2013 - 01:54 PM
Thanks for the (I was going to say feedback here..-s) reply Don. I'm sure I won't have damaged my speaker but I feel it's pain when it happens! I am going to have to give serious thought to cancelling that North Pole gig now though.
#8 brianj402002
brianj402002
  • 76 posts
  • LocationSt. John's
Posted 19 September 2013 - 03:12 PM
I have a quick question regarding the limit indicators. I found in the manual that the front LED's will glow red when limiter is activated. Does the rear panel glow red as well or just the yellow that I see from time to time?
Also tagged with one or more of these keywords: limiter, stagesource speakers
