Loudness difference when wah is switched on
ericvlvn
When I switch on the wah in a certain patch on the firehawk fx I notice that the loudness increases in comparison to the original volume.
It is not possible to change the volume of the wah effect. Does anyone know how to get the same loudness with the wah pedal switched on and off?
It's worth checking what you have the volume pedal set to on the patch, it's possible that you are increasing the volume via the footpedal before the wah is engaged.
I have no increase in volume when I use my wah, but I know all my footpedal settings are at maximum volume for each patch.
The wah does cut through the mix more due to the higher frequencies but it definitely doesn't get noticeably louder
