Case For Jtv 69?
11 replies to this topic
#1 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 11 September 2013 - 05:38 AM
Has anyone here found a case that properly fits a JTV69?  It almost fits in my Strat case but not quite.  The body shape is just enough different to prevent using that.  I plan to travel with my JTV and I don't really want to use the Gig bag when I do.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17811 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 11 September 2013 - 05:41 AM
theres a few options in this thread:
http://line6.com/sup...jtv-59/?hl=case
Phil even has a link to the exact case that ships with the USA 69 models.
#3 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 11 September 2013 - 05:48 AM
I did not see any 69 options there.  That's why I started a new thread.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17811 posts
Posted 11 September 2013 - 05:51 AM
3rd post in the thread from phil:
You can buy the Strat/Tele G&G case (which is what the case the JTV69 comes with is) here: http://www.musicians...-hardshell-case
I don't know about the 59, though. I'm not sure what style case the Us version of the 59 comes with.
#5 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 11 September 2013 - 05:56 AM
Sorry I missed that.  That should work.  My stock plastic Strat case exactly shaped for a Strat and the 69 doesn't fit.
#6 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9046 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 11 September 2013 - 06:14 AM
What Strat case do you have? The old molded cases that Fender used to use for the American Standards and Deluxes won't fit the 69, but the newer ones will fit the 69: http://www.musicians...ric-guitar-case
The G&G case will fit, too, of course. But I have tried my 69 in the newer ATA case Fender uses and it fits. It's a little snug around the body, but I'm sure after a while, the foam would loosen up.
#7 LarryLion
LarryLion
    Iknowathingortwo
  • PipPip
  • 143 posts
  • LocationCaledon, Ontario
Posted 11 September 2013 - 06:45 AM
I bought an SKB hardshell case that not only takes the JTV-69 perfectly, but all it's peripherals too (with the trem bar removed, of course).  Cost under $100 ... check SKB's website.  They definitely have several options.
Larry d'Lion
2012 Line 6 JTV-69
Plus lots of Tele's, Gretsches,
Mesa Boogie amps, Fender Blues Jr.,
... and lots of acoustic stuff
#8 spmartin
spmartin
    Iknowathingortwo
  • PipPip
  • 105 posts
Posted 11 September 2013 - 08:26 AM
I got this case for my JTV-69. Fits like a glove, and a great case! SKB-66PRO
http://goo.gl/XfbGHx
#9 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 11 September 2013 - 08:36 AM
Thanks - sounds like I have a few options.  I have one of the molded Strat cases for an American Standard from about 10 years ago.  The JTV almost fits but not quite.  The cases that are designed for both a Tele and Strat will probably work fine.
#10 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 12 September 2013 - 05:54 AM
I ordered this SKB case from Sweetwater.    http://www.sweetwate...e/detail/1SKB6/  They say it will fit and the latches look much better than the ones on the cheaper Fender cases.
#11 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17811 posts
Posted 12 September 2013 - 05:57 AM
looks like a nice case, but the latches aren't TSA latches... might be important if you needed to put your instrument on a plane...
i actually like the TSA latches although they do seem larger than they need to be.
#12 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 12 September 2013 - 07:09 AM
Not needed for me.  I travel by Minivan. :)   I just wanted something better than the Gig Bag for my Car trips.  I spend winters in Arizona, summers in Colorado.  I take a couple guitars back and forth.
