Simple Question: Logic X Pro
logic x pod hd
Best Answer TheRealZap , 12 September 2013 - 05:54 AM
you generally can't use multiple interfaces (by design) i use my pod 2 ways....
i have a tascam us1800 interface, and from the pod i have analog inputs to the tascam and i also have the spdif input.
i have the spdif input sending dry/unprocessed track for reference...
i add 2 tracks one for each input....
much easier doing it this way because then i can keep everything on one interface... and have no issues using edit or whatever if i wanted to.
if you absolutely must try to get multiple interfaces googles "aggregate devices" for your mac and it may be possible...
keep in mind that you lose some sound quality and performance barriers...
essentially using a single device allows the inputs and outputs to be timed correctly, and mutliple devices can sometimes bring poor results.
Go to the full post
10 replies to this topic
#1 GtarGreg
GtarGreg
  • 10 posts
Posted 11 September 2013 - 04:17 PM
I have a POD HD Pro.  I have installed the drivers via Monkey and am connected via USB to my Mac.  What are the steps for inserting it into a track?  Do I create software instrument track or audio track or what?
I know how to use a stereo out from there to the board and record that - I thought I saw that you can use USB to record and pick you tone from a popup?
So, just looking for step wise instructions.  I cannot find my POD HD in the track info...
Thanks in advance!
Greg
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 12 September 2013 - 04:28 AM
audio track and then select the correct input. its always been that simple for me.
#3 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1133 posts
  • Registered Products:2
Posted 12 September 2013 - 05:01 AM
I don't thin k you can use EDIT at the same time as having the USB connection be available in your DAW.
#4 GtarGreg
GtarGreg
  • 10 posts
Posted 12 September 2013 - 05:46 AM
That might be the case here Thingor2, I'll try that, thank you!
This may be a question for the Logic forums, but it looks like there is not way to select the input source on a per track basis for more than one interface.  What is weird is I can choose the POD as input when creating a new track - but it shows me the Input preference for all of Logic.  So I would be switching away from my Presonus as the input (and I cannot do that).  Everything works when routing traditionally, but I was hoping for additional software functionality in the track.
Come to think of it, is that something you get with POD HD Pro - or can only POD Farm do that?
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
Posted 12 September 2013 - 05:54 AM   Best Answer
#6 GtarGreg
GtarGreg
  • 10 posts
Posted 12 September 2013 - 06:08 AM
That makes sense RealZap - thank you for the clarification!
#7 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1133 posts
Posted 12 September 2013 - 05:00 PM
I am on Sonar X2 and in the preferences you can select available inputs or not. If not selected they don't show on the track. Same for midi devices.
#8 aaronhenry58
aaronhenry58
  • 6 posts
Posted 13 September 2013 - 06:10 PM
I was having the same problem with my hd 500x, and protools. I have to run analog out into mbox pro. Amplitube is nice for editing after the fact, but the 500x sounds soo much bette
#9 aaronhenry58
aaronhenry58
  • 6 posts
Posted 13 September 2013 - 07:01 PM
I was having the same problem with my hd 500x, and protools. I have to run analog out into mbox pro. Amplitube is nice for editing after the fact, but the 500x sounds soo much better. Has anyone had trouble with pod hd edit locking up?
Thanx
#10 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1133 posts
Posted 14 September 2013 - 06:50 AM
Yeah the Amp sims while good don't have the depth and feel of the HD modelling.
I do most of my editing on the HD, it is just as easy to me as EDIT but I have noticed that EDIT takes some time to transfer data to the HD.
#11 GtarGreg
GtarGreg
  • 10 posts
Posted 14 September 2013 - 07:58 AM
L6, if you are listening....regarding Edit....
One thing that is confusing to me:  when the tone in Edit is italicized with a *, meaning the tone is changed in Edit.  How do I know where I tweaked?  Sometimes I grab the knob on the POD and other times I use the Edit UI.  How do I know which side has is changed (software vs hardware) if I forget after moving to another patch?
Also, I find the U/I to be cramped.  I want to be able to expand the window in Edit to full screen to work and so I can see everything clearly.  I practically have to use reading glasses to see everything on my 27" Mac.
Also tagged with one or more of these keywords: logic x, pod hd
