FBV3 am I missing something?
9 replies to this topic
#1 Fleetz
Fleetz
  • 17 posts
  • Registered Products:1
Posted 20 March 2017 - 08:03 AM
Own a Spider V 60W and seriously looking at a FBV3 to open up some features.
Looking into the FBV3 and as a novice trying to make sense of its functionality and operability and all I can seem to find is a polits guide. Am I missing something, is there not a more detailed operating instruction manual on this unit?
The pilots guide is in my opinion is useless. Surely there has to be a detailed instruction manual?
Cheers,
Fleetz
#2 ADBrown
ADBrown
    Line 6 U.S. Product Specialist
  • Product Specialist
  • PipPip
  • 359 posts
  • LocationChicago
Posted 20 March 2017 - 05:24 PM
Right now it seems only the pilot's guide is available for FBV3. If you have any questions about FBV3 feel free to post them here and I'll do my best to help.
#3 Fleetz
Fleetz
  • 17 posts
Posted 24 March 2017 - 04:03 AM
Cheers and thanks for the offer.
When Line6 get serious about writing a useful manual I will get serious about buying a FBV3
#4 NickBell
NickBell
  • PipPip
  • 180 posts
  • LocationCalabasas, CA
  • Registered Products:4
Posted 31 March 2017 - 02:19 PM
Hi Fleetz,
Our current Manual should have all necessary data needed for operation. Are there any details you are seeking that are not listed in the current manual? Please feel free to let us know any questions you may have.   :)
Thank you!
Follow me on Twitter @Line6Nbell
#5 Out2sea
Out2sea
  • 1 posts
  • Registered Products:3
Posted 07 April 2017 - 03:57 AM
Using FBV 3 with Spider Jam IV - Total beginners guide
1. All favourite tones in the Spider Jam must be saved to the User Bank in locations 1A -> 9D for control from the FBV 3.
2. FS1 switches between ‘Normal’ mode and ‘Jam Control’ mode.
Normal Mode
1. Select ‘A’ – saved tone 1A is available; select ‘B’ tone 1B is available, ‘C’ tone 1C is available, ‘D’ tone 1D is available.
2. Selecting Bank up, then ‘A’ displays tone 2A flashing. To select tone 2A, select switch ‘A’ again.
Switches ‘B’, ‘C’ & ‘D’ now contain tones 2B, 2C & 2D respectively.
3. It is easy to have 4 saved tones for a track, in say 3A –> 3D, and bank up to 3 to have all tones available, then bank down to 2, and have 4 different tones available in A, B, C, D (now 2A, 2B, 2C, 2D).
4. Incrementing through each bank is achieved by selecting, say, switch C and banking up/down, then selecting C again when the desired tone is displayed and flashing.
5. Not selecting the Bank switch again whilst the tone is flashing will default to the previous selected tone.
Jam Control Mode
1. Selecting FS1 switches from ‘Normal’ to ‘Jam Control’ mode.
2. Banking up/down moves between saved recordings
3. ‘A’ selects Record or Overdub for either a new recording or a selected track already saved.
4. ‘B’ plays a selected recoded track
5. ‘C’ rewinds.
6. ‘D’ records at half speed. If a lick is recorded at half speed & played back at normal speed it appears an octave higher.
Notes:
1) Unless re-programmed, ‘Function’ switch does nothing with a Spider Jam IV
2) FS2 – FS5 do what they’re programmed to do. Can be re-programmed using Line 6 Editor.
3) ‘Wah/Volume’ always works as switched.
4) ‘Tap’ always does what it does.
5) LEDs do not change colour.
6) Line 6 firmware Updater runs on PC and is connected to FBV 3 via Cat 5 cable. (The Updater works sporadically, if at all – usually a black square with ‘select device to update’ is all you’ll see).
#6 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2539 posts
  • LocationNew England
Posted 11 April 2017 - 04:34 AM
It's no different than the other controller pedals Line 6 have released - the functionality of the pedal, how to use it, is in the amp manual.
#7 Jaseminara
Jaseminara
  • 5 posts
  • Registered Products:2
Posted 17 May 2017 - 09:10 AM
Normal Mode
Jam Control Mode
5. ‘C’ rewinds.
Notes:
Thank you! Now this is helpful, unlike the Pilots guide.......
#8 dkeen1256
dkeen1256
  • 2 posts
Posted 19 June 2017 - 05:38 AM
I bought the FBV 3 new to work with my Spider IV 120.  When I plug it in, the switches may work occasionally, the vol/wah does not switch, the sound erratically changes from loud to soft.  Do I have a bad unit or is there something I need to do in terms of upgrading the firmware on the Spider IV or the FBV 3?
#9 ADBrown
ADBrown
  • PipPip
  • 359 posts
  • LocationChicago
Posted 19 June 2017 - 08:12 AM
I would definitely start by making sure the firmware is up to date on both units. I know there was an update for FBV3 early on that may solve your problem
#10 dkeen1256
dkeen1256
  • 2 posts
Posted 19 June 2017 - 08:34 AM
Thanks. I will give this a try.
