tal688 Posted March 21, 2017 Share Posted March 21, 2017 I own a Pod 3X live, and today i downloaded the GearBox software for the first time. The download ended succesfuly, and it works fine with the Pod device. However, every time i connect the Pod and opens the GearBox program, it shuts of the WIFI stick. Therefore i can't have an access to the tone library. And in order to get an internet connection, i must disconnect the Pod, close GearBox and reset the WIFI device. Does anybody had a similar issue? What can i do to fix it? Thanks a lot!! Quote Link to comment Share on other sites More sharing options...
Cellspy Posted April 30, 2017 Share Posted April 30, 2017 I have the same issue ,was working on it just before my friend bombed my Pod,priority has changed .I can tell you this I found a script had been added to the set up for the IE connections.that is designed to override the proxy settings. The script seems only to effect IE .why line 6 would mess at this level is strange . It is not in my standard IE settings however Quote Link to comment Share on other sites More sharing options...
