m20d footswitch
media player
Best Answer Rewolf48 , 28 March 2017 - 12:38 PM
I raised an Ideascale to enhance Helix to include a momentary action on the Ext Amp output - this could be used for other purposes such as Keyboard Sustain/Damper as well as M20d control:
https://line6.ideasc...ut/890041-23508
Go to the full post
10 replies to this topic
#1 MarkPod300
MarkPod300
  • 26 posts
  • Registered Products:6
Posted 26 March 2017 - 02:42 AM
Hi, I am interested in the media player feature of the m20d.
In the manual it is written that there is a footswitch that allows to toggle between stop/start of the playlist.
I can not find this foot switch. Does anybody has experience with that.
I also have a Helix. Would it be perhaps possible to asign a foot switch of the helix to do that?
Tks
Markus
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 26 March 2017 - 04:13 AM
There are two footswitch jacks on the M20d right beside the headphones jack. You need to connect an external footswitch just like you need to connect headphones.
No you cannot use the Helix footswitch for this purpose.
.... John Lennon
#3 MarkPod300
MarkPod300
  • 26 posts
Posted 26 March 2017 - 05:05 AM
Thks, any footswitch or a specific one?
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
Posted 26 March 2017 - 05:12 AM
Any footswitch should work. The M20d manual should include any constraining specs.
.... John Lennon
#5 SiWatts69
SiWatts69
    Gear Head
  • PipPipPip
  • 509 posts
  • LocationSouth Yorkshire, UK
  • Registered Products:13
Posted 26 March 2017 - 01:34 PM
Footswitch should be "momentary" type.
Complete DreamStage:
M20d with 2x L3m, 2x L3s, 2x L2t & 2x L2m
XD-V75HH & XD-V75BP wireless
#6 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1234 posts
  • LocationUK
Posted 27 March 2017 - 04:40 AM
Are you sure about the Helix to M20d connections?
I haven't tried it (I haven't used footswitch control on my M20d yet), but according to the Helix manual the Amp Switching output mimics a pair of simple switches:
EXT AMP 1/2 Connect to your traditional guitar amp to switch its channels or turn its reverb on and off. Use a TRS cable for dual operation (1=tip, 2=ring).
So with a cable that is TRS Jack at the Helix end to dual TS Jack (a simple 1/4 stereo split to 1/4 mono cable) you should be able to define momentary switches on Helix (in pedalboard mode) that will activate the foot switch functions on the M20d.
Or am I missing something? I might give this a go tomorrow with a simple guitar lead for single switch operation and report what happens (rehearsal tonight)
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
Posted 27 March 2017 - 04:46 AM
That's interesting and you may be right. I didn't test either before responding and I hadn't considered that. Please do report back on your findings.
.... John Lennon
#8 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1234 posts
  • LocationUK
Posted 28 March 2017 - 12:10 PM
Test complete - it's one of those "close but no cigar" moments...
I connected the Helix to M20d using a stereo 1/4 jack to dual mono 1/4 jack lead - output from the Helix Ext Amp to the M20d footswitch inputs.
I set M20d to play/stop with one footswitch and next track with the other and inserted an SD card with 5 mp3 tracks on it and set up a quick playlist with the 5 tracks. Note - this always starts the track from the beginning.
On Helix I used command centre to set a pair of footswitches to control tip and ring outputs - the only options available.
Then I started pressing footswitches and ran into the M20d latching/momentary problem.
The M20d requires momentary switches (I have a keyboard sustain that works perfectly - given the limited functionality on M20d)
The Ext Amp switches on Helix are latching.... yes it does Start/Stop and switch to the next track when you press the Helix switches. But you have to press twice to get the M20d to respond, so as it stands it is not very useful.
The only way that this will work in a useful way is if a future upgrade of Helix gets it to support momentary switching on the Ext Amp outputs, but at the moment I think buying a dual momentary footswitch is the easiest option.
#9 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
Posted 28 March 2017 - 12:15 PM
Interesting. Thanks for the report.
.... John Lennon
#10 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1234 posts
  • LocationUK
Posted 28 March 2017 - 12:38 PM   Best Answer
#11 MarkPod300
MarkPod300
  • 26 posts
Posted 09 April 2017 - 08:36 PM
Thks for the replies
Also tagged with one or more of these keywords: media player
