Resonance From Dt25 Valves
Best Answer GrahamGunn , 29 September 2013 - 05:22 AM
The amp had (Russian) Electro Harmonix EL84 valves that needed to be replaced. In the end I replaced them with ones from Watford valves. Much better. Go to the full post
6 replies to this topic
#1 GrahamGunn
GrahamGunn
  • 5 posts
  • Registered Products:4
Posted 13 September 2013 - 04:01 PM
For all options I-IV on my DT25 there is a resonance with any C# note on the guitar. (It's not the guitar, or the player!)
Any ideas?
#2 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5353 posts
  • Registered Products:6
Posted 16 September 2013 - 05:55 AM
Is this a plate rattle? maybe...If so, you might can verify it better with a pencil...tap each tube with a pencil, if you hear it...you have some microphonics and you need new tubes...if the amp is less than 90 days, I think Line 6 has a 90 day warranty on the tubes...
#3 saTa
saTa
  • 49 posts
  • Registered Products:1
Posted 21 September 2013 - 05:32 AM
Haha, I get the same on a B note...
#4 PeterGurton
PeterGurton
  • 6 posts
  • Registered Products:2
Posted 25 September 2013 - 09:13 AM
I am getting a similar problem with my spider valve when I play a B maj chord. I hit the chord, then mute the guitar and a resonance note at 192Hz just sings out and wont go away until I turn the standby off. Very annoying as I start in a new band next week.
I can send a sound file if need be.
#5 jamieabraham
jamieabraham
  • 5 posts
Posted 29 September 2013 - 03:09 AM
My DT25 came fitted with cheap Chinese valves - I changed them for decent quality Russian ones and it sounds much better
#6 GrahamGunn
GrahamGunn
  • 5 posts
Posted 29 September 2013 - 05:22 AM   Best Answer
#7 GrahamGunn
GrahamGunn
  • 5 posts
Posted 29 September 2013 - 05:25 AM
Also, spaceatl, the pencil test worked much better when the amp was on!
However it then sent the whole amp microphonic. Still, as I said, much better now.
