Can The Effects/patches Be Assigned To Specific Outputs
hd 500 combo amp
Best Answer silverhead , 04 May 2013 - 09:37 AM
Perhaps the four-cable method of connecting your amp and HD500 is what you want:
http://line6.com/support/docs/DOC-2504
I think this will let you do what you want by using an HD500 preset with no amp, some FX placed before the HD500 FX Loop, and some after.
Go to the full post
5 replies to this topic
#1 raymon68
raymon68
  • 3 posts
  • Registered Products:1
Posted 04 May 2013 - 05:27 AM
I want to know if i can assign effects/patches to specific outputs on HD 500?
Example: i want wah-wah effects to go into the intstrument in on my amp and i want to have an active delay in my amp's effects loop? Is panning the way to do that?
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15698 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 04 May 2013 - 06:30 AM
You can't directly assign specific FX to specific outputs. Panning may be helpful, as may the HD500 FX Loop - can't say without more specifics, but give it a try.
.... John Lennon
#3 raymon68
raymon68
  • 3 posts
Posted 04 May 2013 - 06:41 AM
Okay let me ask in a different way. I want to have two effects chains running simultaneously. One from my guitar to the instrument input on my amp. For the next loop i want use the effects loop on my amp. The problem i am trying to solve is that I spent good money on an Amp that is modeled in HD 500. So i want use the actual preamp for clean and crunch. But as we know some effects are more effective between the guitar and the amp and other effects are more effective in the FX. So i am looking for a way to get that flexibility.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 04 May 2013 - 06:56 AM
so you want an effect chain/model through the left side, and a dry signal through the right pretty much?
that's possible, many use that to record the dry track.
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15698 posts
Posted 04 May 2013 - 09:37 AM   Best Answer
.... John Lennon
#6 raymon68
raymon68
  • 3 posts
Posted 04 May 2013 - 12:08 PM
That is it! Y'all nailed it.
Also tagged with one or more of these keywords: hd 500, combo amp
