Shuriken Presets Download?
dbagchee
  • 11 months later...
Guest abonica
On 3/19/2018 at 10:30 AM, psarkissian said:
Once downloaded to your computer, use Workbench HD to load them into your guitar. As far as I know, these are not compatible with other JTV or Variax Standard guitars. These are for the Shuriken exclusively.
All guitars with Variax HD firmware use the same models, so they'll work with any guitar running Variax HD (2.0 and higher) firmware. The stock tuning presets that come preloaded in Shuriken are only preloaded in the Shuriken, but are easy to custom make using Workbench HD for any of the other SKUs.
Guest abonica
On 3/21/2018 at 8:11 AM, SymphonicDischord said:
Be aware though, that if you do decide to download The Shuriken presets, Stevic has his guitar tuned to Dropped D and all his custom tuning adjustments reflect this. So you’ll either need to tweak them in Workbench or retune your Variax accordingly.
Correct, this is true for the tunings saved with the model in the following preset banks: User I, II, III, IV, and Shuriken. However, the alternate tunings saved on the tuning knob are relative to standard EADGBE physical tuning.
