LarryStephen Posted September 14, 2013 Share Posted September 14, 2013 I have a PODHD500. I've assigned volume pedal successfully to most of my patches. One patch is not allowing me to do it. I've cross checked setting to patches where the pedal works. They're identical. Only thing I see that's different is an asterisk appears on the patch that's not working. I notice that the EXP light is not turning green. Stays red. I don't have a wah patch assigned. I tried that to see if it would switch back and forth when stomping on the pedal. No go. Any ideas? Please help!!! Disgruntled POD user Quote Link to comment Share on other sites More sharing options...
slurry Posted September 14, 2013 Share Posted September 14, 2013 Hmm. I haven't run into this issue before (if it ever doesn't default to vol pedal, I just stomp it to switch to it), but just some ideas of things you could do to work around it: First, I would say to double-press Move while highlighting the vol pedal in your chain, and make sure that it is assigned to one of the expression controllers. Then I'd check in HD Edit to see if I can assign it through there. Next, I'd go through and check it any other pedals in my chain is assigned to the expression controller that I want to use for my vol pedal. If that doesn't work, I would say to remove the vol pedal from your chain, then save the patch to a new location, and try adding the vol pedal on this new patch and see if that'll work. Good luck! Quote Link to comment Share on other sites More sharing options...
LarryStephen Posted September 14, 2013 Author Share Posted September 14, 2013 Thanks. I tried all of them with no luck. Could be a technical issue with my box. Quote Link to comment Share on other sites More sharing options...
slurry Posted September 14, 2013 Share Posted September 14, 2013 Is it possible to create a new patch with a vol pedal that works? Quote Link to comment Share on other sites More sharing options...
LarryStephen Posted September 14, 2013 Author Share Posted September 14, 2013 I switched controller to EXP1 and it worked. Not sure why but will take it. Thanks Quote Link to comment Share on other sites More sharing options...
slurry Posted September 14, 2013 Share Posted September 14, 2013 Great! At least it's working. :) Quote Link to comment Share on other sites More sharing options...
