Firehawk FX - Expression pedal clicking
C4ptainCh4os
Hi guys,
After a poor experience with a Line 6 Spider II amp I moved away from Line 6 products for quite a while. Then the Helix came out and I was really impressed but for now it is way out of my price range, and so is the Helix LT.
I have a TC Nova System which I have always struggled to setup as it seemed overly complicated. So when I found out about the about the Firehawk it was not only affordable it looked so much easier to tweak.
Getting to the point I bought a Firehawk and I love it, but after a few weeks I have found that the Expression Pedal has an intermittent mechanical clicking sound when rocking back and forth on it. I can 100% say that I have never put full weight on it as I am a guy of medium build so I always make sure that I keep the weight on my left leg and light pressure on the pedal.
I just wondered if anyone else has experience this as it just doesn't sound right, so I am wondering if this can be adjusted out using the supply allen key or should I just return the unit for a replacement.
Thanks in advance.
C4ptainCh4os
http://line6.com/support/topic/21885-expression-pedal-squeak/
You are not alone. I have found that the noise can be eliminated with +-zero pressure (just barely move from heel to toe without pressing).
I am also using two Ernie Ball Jr. as a 2nd expression pedal for FH and M13 respectively, consisting of a simple string mechanism, and they have  not made any noise for the past couple of years. I guess it is how it is designed.
