Is There A Way (i.e. Different Tubes, Etc) To Minimize Master Volume On Mkii 212?
7 replies to this topic
#1 Scaryfast
Scaryfast
  • 9 posts
  • Registered Products:4
Posted 16 September 2013 - 08:02 AM
I have a Mkii 212 which I love, but like many, I have issues if the models have the channel volume below 50% or so.  Some people experience a dropout of volume...I experience a "POP".  However, if I have the channel volume at 50%, the overall volume is SO LOUD...unless I'm playing in a big room, it's unbearable.  Has anybody found a way to work around this by possibly adjusting the master volume potentiometer, software, or tubes to bring the overall volume down just a bit so we can run the required 50% channel volume to eliminate the pop or dropout?
Thanks.
#2 pillbug
pillbug
  • 21 posts
  • Registered Products:3
Posted 12 October 2013 - 04:50 PM
Hi, you need to get something like a Power Soaker, Super Soaker... I have the THD Hot Plate (purple one) which I have attached to the back of the amp in always-connected mode and it works great, allowing me to turn up the Master volume past 2 (usually no more than 5 / i.e. halfway) without shattering the windows.
  • 1
#3 Scaryfast
Scaryfast
  • 9 posts
Posted 27 October 2013 - 12:27 PM
Thanks.  I've thought about that but glad to hear from somebody who's actually done it.
#4 edfardos
edfardos
  • 8 posts
  • Registered Products:1
Posted 13 May 2014 - 05:07 PM
On my hd100 with four power tubes, i've removed the inner two tubes for an aparent 15% volume reduction. Be sure to rebias the amp if you do.
#5 severalbeans
severalbeans
  • 1 posts
Posted 27 October 2014 - 10:13 AM
i solved this problem with a simple volume box in the effects loop (preamp out / power amp in).  it is a simple effects enclosure with a volume pot that let's you throttle back the preamp volume before it hits the power amp.  i have my master volume at about 9:00, and the channel volumes on my presets around noon, and can roll the output volume back to whisper quiet with negligible tone loss, and there is no pop when i change channels.
these things cost $20-30, or you can easily make your own for less than half that.
note:  this is NOT an attenuator -- it does not 'swallow' power before it hits your speaker.   attenuators are a whole nother thing, cost a LOT more, and suck tone when trying to bring a big amp to bedroom volumes.
Vick Audio makes one called a 'tube tamer'.  or look for 'guitar volume box' on ebay.  look for something that has an input, output, and single knob that costs around $20.
#6 Hollatchaboy72
Hollatchaboy72
  • 22 posts
Posted 29 October 2014 - 09:01 AM
I have my pod x3 live running thru the effects loop I can turn the master volume on the amp up and the master volume on the x3 down. I can't turn the master down on the x3 too low tho but it's a good way of taming the volume on the sv.
#7 Flinky
Flinky
  • 2 posts
Posted 31 October 2014 - 05:45 AM
there's a setting for the pedal volume (min, max) .... just set it to e.g. max 60% and feel free to turn up the channel volume above 50%.
I think it would also work, even without a pedal attached!
#8 lincland
lincland
  • 1 posts
Posted 03 January 2015 - 09:34 AM
I have an SV 112 and an HD 100 with a bogner 212 cab. An easy fix is to go through and reduce all of the channel volumes of the patches you use on your gig.
At first I was having to run the master at about 1, with my channel volumes around 90%. Over time I lowered all my channel volumes down to between 15% and 25%, and now I run my master at about 6 on the same gig. The sound is better.
