Doing Factory Reset On Alt. Tuning.
7 replies to this topic
#1 broker2
broker2
  • 76 posts
  • Registered Products:1
Posted 17 September 2013 - 03:57 AM
Hi guys do i have to flash back to 1.9 to do a factory reset on the alt. tuning or do i have to go back farther than that like back to the 1.82. Thanks for your help cal.
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 17 September 2013 - 04:21 AM
just reflash to your current firmware whatever it would be.
#3 broker2
broker2
  • 76 posts
Posted 17 September 2013 - 05:01 AM
You can not do a factory reset on the alt. tuning when in 2.0 firmware.
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16051 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 17 September 2013 - 05:05 AM
Not sure I understand. Are you saying that when you install (or reinstall) JTV firmware v2.0 it does not restore the factory set of alternate tunings? I've not specifically tried this but I would be surprised if it does not restore them.
.... John Lennon
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 17 September 2013 - 05:08 AM
reinstalling the firmware is a factory reset.
#6 broker2
broker2
  • 76 posts
Posted 17 September 2013 - 05:44 AM
If you read the manual it says you can do a factory reset on just the alt. tuning but what they tell you to do does not work when you are in the 2.0 so i was wondering if i had to reinstall 1.9 or go back farther to get that factory reset on the alt. tuning to work.So you are telling me if you install 2.o it also sets up the alt. tuning. thanks for your time cal.
#7 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
Posted 17 September 2013 - 05:53 AM
yes reinstalling the firmware will reset the alt tunings, its the only way that works with 2.0 currently. you will however lose any custom models you've added or changes you've made.
I always advise backing up your current models and allow the firmware to overwrite them all to factory... then if desired restore the backup.
(this only works in like for like firmwares... meaning 2.x-2.x or 1.x to 1.x not 1.x to 2.x)
#8 broker2
broker2
  • 76 posts
Posted 17 September 2013 - 06:03 AM
Ok thanks for your help  cal.
