Addin my hd500x in front of my stompboxes
Diablo1
I tried to add my hd500 in front of my pedal chain... guitar into hd500x, come out of right mono into the start of my stompboxes then out of my 10 pedals into my amplifier.
I didn't have a fuzz pedal so I wanted and felt like adding a fuzz face to my pedal chain so thought of my hd500x to add a pedal I didn't have, but when I added just a fuzz face to the hd500x and wanted no amplifier in the hd500x cause I was using my own amp the volume was low even with guitat volume turned all the way up?
Where should I put my hd500x in front or at the end of my pedal chain? Which mono should I come out of right or left or is there another way to connect it into my pedal chain new to trying to add them both together?
Thanks
the 500 should be your pedal chain. nothing in front. nothing behind.
BUT, if you insist on using other stuff, the fx loop is always best. That way you can decide when to use them, as well as determining if you want them in front of behind something or maybe even in the middle.
