Kehatrong123 Posted May 18, 2017 Share Posted May 18, 2017 Hi, I am new to line6 stagesource speakers. Just got 4 L3t's with 4 L3s's subs setup with Midas M32. Please help me how to set this right. Do I have to use Link6 cable or just regular xlr? Which crossover setting for this speakers. Thanks so much for all of your help Best regards Tran Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted May 18, 2017 Share Posted May 18, 2017 L6Link is a proprietary system, so any connections form other desks needs to be analog. Run an ordinary XLR from main out L on your Midas to first L3s on Left Run an ordinary XLR from main out R on your Midas to first L3s on Left Run L6Link cable to daisy chain all the Line6 speakers via their L6Link in/outs Set Crossover frequency on L3s Alternatively, you can cable each side of the stage from its dedicated L/R output and just run the L6Link daisy chain within the 4 speakers in the stack on each side. There's a visual of the recommended setup on page 22 of the stagesource L3s manual: #http://uk.line6.com/data/6/0a06434d9ac8502007180aca2/application/pdf/StageSource%20L3%20Quick%20Start%20Guide%20-%20English%20(%20Rev%20C%20).pdf Quote Link to comment Share on other sites More sharing options...
Kehatrong123 Posted May 18, 2017 Author Share Posted May 18, 2017 Thanks so much for quick response. One more question, if I want to run those L3s subs on AUX how can I set this up with link6 cable with Midas M32.Thanks again Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 18, 2017 Share Posted May 18, 2017 As SiWatts69 indicated your Midas M32 cannot communicate via L6 with the Stagesource speakers. The M32 does not have an L6 Link digital output; you need to use its analog outputs, which also happen to be XLR but do not handle the proprietary L6 Link protocol. Quote Link to comment Share on other sites More sharing options...
Kehatrong123 Posted May 19, 2017 Author Share Posted May 19, 2017 Thanks so much Quote Link to comment Share on other sites More sharing options...
