Jtv-69 5 Way Toggle Piezo Pickups Will Not Stay On Position 2 Or4
jtv-69 jtv 69 5 way toggle toggle switch problems issues 2 and 4 intermittent not working unplayable
11 replies to this topic
#1 bsbarber73
bsbarber73
  • 5 posts
  • Registered Products:4
Posted 18 September 2013 - 11:36 AM
Just purchased a JVT- 69 and noticed when using the mag pickups the 5 way toggle switch works perfect but when I switch to the virtual instruments position 2 and 4 don't work right. In either position the instrument is intermittent. I have to hold the switch a little out of that location to get it to work and then when I let go, it goes back to the instrument on either side of that position even though it is still in position 2 or 4.
I updated to the latest firmware and It seemed like it got worse. Has anyone else had this issue. It currently renders the virtual Side of the instrument almost unusable. I have not found anything on this issue other that one other guy made a video on YouTube and his was really bad (hence his cursing in the background).
#2 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 18 September 2013 - 12:01 PM
Sounds like you have an electrical problem.  The switch serves two different functions:  One is to select the mag pickups same way as a Strat.  The other is to select one of five Models in the bank.  Sounds like the second function isn't calibrated correctly.  I would send it back.
#3 bsbarber73
bsbarber73
  • 5 posts
Posted 18 September 2013 - 07:26 PM
Charlie You are probably correct in your assumption and I thank you for your quick reply. I have created a ticket and now I am waiting for a response. Meanwhile if anyone has any knowledge to weather this can be recalibrated either with software or physically without voiding the warrentee please educate me. I would love to resolve this without having to send it back.
#4 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 18 September 2013 - 07:30 PM
I have not seen any sort of "calibration" proceedure anywhere.  Line6 may have one but you may have to send it to them to get it done.  If you just bought it can you return it to the seller?  This is certainly a defect.
#5 bsbarber73
bsbarber73
  • 5 posts
Posted 18 September 2013 - 07:49 PM
Got it from guitar center and the knocked off $285 because of the issue and it would cost me that much more to get one on exchange.
#6 arverutledal
arverutledal
  • 10 posts
Posted 03 October 2013 - 02:47 AM
Hi,did you get the 5 way toggelswitch fixed?
I have the same problem with my jtv69
  • 1
#7 brain4000
brain4000
  • 8 posts
  • Registered Products:3
Posted 15 September 2017 - 11:38 PM
Did you find a solution to this issue?
#8 cruisinon2
cruisinon2
    Uber Guru
  • 5413 posts
  • Registered Products:5
Posted 16 September 2017 - 07:24 AM
This thread is 4 years old...don't be surprised if you don't get any responses.
#9 Thehatman
Thehatman
  • 2 posts
  • Registered Products:2
Posted 06 October 2017 - 03:38 PM
I just purchased a brand new JTV59 from Sweetwater and it has the same issue right out of the box.  When I first tried it it was cold from being in the delivery truck.  After is warmed up, the problem went away.  The next morning it was back.  After being plugged in for a couple of hours to the power supply it was fine again.  I was suspecting a cold solder joint on the switch and removed the cover.  The black wire at the top has a dull solder connection, which could be the culprit.  Rather than taking a soldering iron to a brand new guitar, I contacted Sweetwater and they arranged to replace the guitar.  If your guitar is out of warranty, I would look at the connections, or enter a ticket with Line 6.  It's always better to have a trained Technician work on your guitar.
PS: I also have a v700 that I love.
  • 1
#10 psarkissian
psarkissian
    Line 6 Staff
  • Service Engineer Moderator
  • 1950 posts
  • LocationCalabasas, CA
Posted 06 October 2017 - 03:52 PM
I hope you put the cover back on in the correct orientation with the
tape, so that the foil under the cover doesn't short the toggle switch.
#11 Paule315
Paule315
  • 10 posts
Posted 27 December 2017 - 10:20 PM
I have this issue as well position 2+4 don't work. is there a fix other than sending the guitar hundreds of miles
#12 jerseyboy
jerseyboy
  • 87 posts
Posted 28 December 2017 - 07:12 AM
Even in a perfect world JTV59 2/4 model switching can be a delicate flower, IMO.  Workaround for me is simply program/load models that I know I’ll need in 1/3/5 positions and rarely ever use the tuning knob on/off switch to toggle 2/4.
Please note - I dunno anything 1st hand about JTV69 hardware I’m speaking only about JTV59.
Also tagged with one or more of these keywords: jtv-69, jtv 69, 5 way toggle, toggle switch, problems, issues, 2 and 4, intermittent, not working, unplayable
