Pod 2.0 Ouput Too Low, Noisy
3 replies to this topic
#1 Baja4Bob
Baja4Bob
  • 2 posts
Posted 18 September 2013 - 11:53 PM
Hi Folks!
The poster of this previous thread expresses exactly the problem I've had for years with this device.
http://line6.com/sup...ew/thread/26541
But that thread can only be accessed to read, not to add more postings ...
What is the fix for this problem?
It doesn't matter what I plug that POD into, I get the same results from it's Left/Right outputs.
It is noisy, with low output levels ... even noisier when the level is externally boosted ...
I've used MOTU Traveler units, Yamaha O1V mixer units, Waves L2 units, and a Presonus Blue Tube .... others ...
All noisy, with low output levels ... even noisier when the level is externally boosted ...
I'm running the chip rev 2.3 since 2008, but that didn't make any difference with the noise issue ...
All help with this problem very welcome!
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
  • Registered Products:6
Posted 19 September 2013 - 04:18 AM
Are you saying the POD is noisy going into these units, or are you saying these units are also noisy with no POD?
#3 Baja4Bob
Baja4Bob
  • 2 posts
Posted 19 September 2013 - 07:50 AM
Thanks for your response Triryche!
All those units work perfectly fine for all uses, producing no audible noise of their own for many other uses.
I mentioned them as examples of the fact that the noise is definitely being produced by the POD, in many different circumstances.
Is it possible to stop this noise from happening?
The description in that link in my original posting is accurate to my experience, except I have not tried the headphone output into any system yet.
I only just discovered that posting late last night.
I note there was no fix mentioned in that post, and no way to respond to it.
Surely, there must be a better fix than using the headphone output ....
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 19 September 2013 - 07:56 AM
I don't think what you describe is normal, some have had luck with the headphone out increasing the signal to noise.
If you run the L/R out into an amp or monitors to you experience the same issue?
