Can you help my? Another general output
1 reply to this topic
#1 larryamza13
larryamza13
  • 1 posts
Posted 07 June 2017 - 04:22 AM
Can you create another general output on the m20d mixer? Or an auxiliar stereo output that can be controled by the main volume
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15858 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 07 June 2017 - 04:45 AM
You can use the monitor outputs to send output signals to whatever device you like. Create a monitor stereo pair in Setup mode. Use the channel monitor assignments to control the mix and the monitor level controls to adjust the output levels. You can link or unlink the channels to the monitor level as desired.
However, the manual states that the Master Volume knob only controls the level of the Main stereo outputs. Sounds like you cannot control the monitor outputs by this knob, but you can check this yourself.
.... John Lennon
