Please Help Me Set My Rig Up!
5 replies to this topic
#1 jeremiahzellers
jeremiahzellers
  • 9 posts
Posted 21 September 2013 - 10:14 AM
Hello... I'm admitting defeat and asking for help.
So, here is where I'm at... I just bought a new ART SLA-2 Power amp that I want to run my HD500x into.  Problem is, I have to crank the ART and the HD just to get a volume loud enough to get over a drummer.
My set up is guitar > HD > ART Bridged mode (530 watts and 8 ohms) > 4x12 cab running mono 16 ohms.
Now, I know that running 8ohm head to 16 ohm cab will cut down the watts some, but It's crazy quiet.
If I set the HD to "Line" mode instead of amp, it's louder and and comes very close to getting loud enough in the mix, but it feeds back TERRIBLY and there is a constant unholy noise or robotic sounding hiss. (I have to max all volumes on the HD)  I uploaded a video of the crazy noise that it emits... it's a cellphone video, but it gives you an idea.
I have tried all the various output settings and nothing seems to work.  So, how can I set this up so that I don't have to crank all the volumes to get close to a useable live volume???
#2 brue58ski
brue58ski
    Power User
  • PipPipPipPip
  • 1241 posts
  • Registered Products:13
Posted 21 September 2013 - 12:36 PM
This is a huge guess but I noticed that when running in bridge mode, you're supposed to connect to the two red output posts as opposed to a black and red one.  I'm not sure what happens if you connect to the black and red posts in bridge mode but it looked like a mistake I would easily make.  Hope it's as easy as this.
#3 jeremiahzellers
jeremiahzellers
  • 9 posts
Posted 21 September 2013 - 04:53 PM
Hello,
I checked and I have it plugged in correctly. It's weird. From what i've been reading, this thing should be rattling windows with room to spare....
Not sure what else it could be.  Plugging into a power amp.. what should the pod be set to?
#4 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1025 posts
  • Registered Products:2
Posted 21 September 2013 - 05:30 PM
Does the amp have voltage taps from the output transformer?
Are you going into it monoL out of the HD?
EDIT: I just googled it and looked at the specs. The output is for stereo 4 or 8 ohms .
You'll have to rewire your cabinet so it'll be 8 ohms. The loudest will be a 4 ohms load.
#5 jeremiahzellers
jeremiahzellers
  • 9 posts
Posted 21 September 2013 - 06:43 PM
Hello
Thanks for the reply. As far as I know, there is no voltage tap.  I will look for a instructions on rewiring my cabinet.  Hopefully it's not too difficult
Do I have things set up correctl?  I am going Mono Left out of the HD into the power amp.  I have the output setting on Stack Power (or something like that) and I have the switch on the front set to line (amplifier setting is way too quiet).  Is this how I set it to run into a power amp?
#6 still_fiddlin
still_fiddlin
    Iknowathingortwo
  • PipPip
  • 142 posts
  • LocationTexas
Posted 21 September 2013 - 08:02 PM
I assume the HD500X phones out is very loud?  Assuming it is, I'd try a different power amp and see if it works, or go direct to the PA for a check.  Try a different line input to the amp and see if it works Ok.  Try a different cable.  The usual stuff.  Isolate and test.
