Ground loop buzz and volume/wah pedal
buzzing pod x3 live pedal noise
1 reply to this topic
#1 terrywood
terrywood
  • 4 posts
  • Registered Products:1
Posted 19 June 2017 - 09:02 PM
System: Pod X3 Live
Amp used:  Vox AC-16 connected using a cable that's XLR female/TRS 1/4"
Has anyone had this issue:
1. An annoying buzz which seems to come and go when I touch the volume/wah pedal?
2. A squeaking sound when you move the volume/wah pedal?
I bought this unit in 2009 and this has happened increasingly over the past few months.
I cleaned the outside of the unit and sprayed  all the connections with contact cleaner.
#2 patdixon
patdixon
  • 41 posts
Posted 20 June 2017 - 11:17 AM
Sounds like 2 different things. For the 1st part, what happens if you use one TS cable from a live output to the input jack on the amp?
#2 sounds like mechanical noise; contact cleaner will only make that worse. Try some graphite (pencil lead works) at the pivot nut if you can get it in there.
Also tagged with one or more of these keywords: buzzing, pod x3 live, pedal noise
