My POD HD Pro isn't recognized no matter what I do
alvinsg
Hey guys, I finally got time to mess around with my Line 6 POD HD PRO so I downloaded POD HD Pro Edit to start making tones.
Problem is, no matter how many times I install the driver and reset the my Mac, the driver never actually installs and Monkey wants says my device is not connected.
I'm connecting via USB (the Rocksmith cable to be exact, I've been told it works for this) if that helps. I'm connecting it via the dry output but I'm not really sure what the difference is between all the in/out stuff back there. I'm sort of new to this so yeah.
Any help would be appreciated!
Though I am not on a Mac this might not be too much help.
Make sure your USB is not via a hub. Go the main USB.
On PC you need monkey and this might be all you need. Let Monkey do
the install for you.
On the older PCs you can uninstall the drivers and HD EDIT then at startup  the OS wants to
find driver for the HD or device. In case via monkey is a prob.Good luck
