Hybrid Guitar Question
ConnerNA
Long time NI GuitarRig user, I have a few questions to see if the Helix LT will fit the bill for my GR replacement.
Currently I use a Tele with a Fishman power bridge (ie a Hybrid), I run stereo out from the guitar (right channel is the eclectic and the left channel is the fish man power bridge), into my GR floor controller. I send the two singles down two different chains and then use a split that is assigned to an expression pedal to pan between the two signals. This allows me to play a blend of both.
Would a setup like this be possible in Helix LT (the most important part being the assignment of the split to the expression pedal)?
Hope my description makes sense.
Yes this is possible. You can use the guitar input and the effects loop for additional inputs. From there it would be possible to build a preset where the expression pedal is used to blend the signals.
