Speakers - Inside the Spider V 240 with the Back Panel off...
10 replies to this topic
#1 bluebluetones
bluebluetones
    Iknowathingortwo
  • PipPip
  • 273 posts
  • Registered Products:1
Posted 26 June 2017 - 03:15 PM
I had always been wondering about what kind of speaker are included in the Spider V series amps, and I was surprised there was little info available on the internet.
I was very curious what the sound of the amp might be like with the back panel off.  I really like playing my Spider IV with no rear panel, as well as with a lot of my other amplifiers.  I decided to take a look.
The speakers have pretty small magnets for a "120 watt" speaker - I don't think they would put out much SPL.  I turned the 240 model right up, and it did not feel as loud as my Spider IV 120 amp, but volume is a difficult thing to measure (not to mention it being uncomfortable in the same room at that level!)
The electronic mounting plate would not allow me to completely remove the back panel... :(  I have to decide whether I would remove the panel or simply modify the back panel so that the speaker compartment would be open.  That would be nice, because I could open or close the back depending on what kind of experimenting I would like to do.
The inside of the amp is built very nicely, with bracing and ports on the front.
The speakers are labelled 300RFL06...a quick look on the internet shows Chunil Corporatin, who make speaker for Line 6 and Marshall.
http://www.kicschunil.com/
Here are two profiles of the 300RFL06 speakers - these have different wattage and ohms.
http://www.kicschuni...tail.asp?id=161
http://www.kicschuni...tail.asp?id=168
Attached File  1.JPG   576.04KB   13 downloads
The back of the amp
Attached File  2.JPG   409.37KB   6 downloads
Attached File  3.JPG   745.7KB   6 downloads
Showing the speaker and interior
Attached File  5.JPG   650.06KB   9 downloads
Attached File  6.JPG   680.16KB   10 downloads
The Tweeter
Attached File  7.JPG   602.5KB   10 downloads
The 120 Watt speaker...very small magnet for a 120 Watt speaker.
#2 d3wjhwlk7
d3wjhwlk7
  • 9 posts
  • Registered Products:2
Posted 27 June 2017 - 03:22 PM
Being somewhat of a thicko on this, Would I be able to transfer my Celestion Vintage 30's (marked as 16ohms) to my v 240?
#3 psarkissian
psarkissian
    Line 6 Staff
  • Service Engineer Moderator
  • 1896 posts
  • LocationCalabasas, CA
Posted 27 June 2017 - 03:58 PM
"Would I be able to transfer my Celestion Vintage 30's (marked as 16ohms) to my v 240?"---
No. Don't do that.
What is in there, is in there for a reason,.... don't mess with it.
#4 guitardad123
guitardad123
    Iknowathingortwo
  • PipPip
  • 205 posts
Posted 27 June 2017 - 07:46 PM
Those are 4 ohms speakers in there. 16 ohm speakers will not help to obtain more power
#5 gtrman100
gtrman100
    Gear Head
  • PipPipPip
  • 574 posts
  • Registered Products:8
Posted 27 June 2017 - 11:01 PM
#6 fearuvthedark
fearuvthedark
  • 12 posts
  • Registered Products:7
Posted 07 December 2017 - 12:36 PM
"The 120 Watt speaker...very small magnet for a 120 Watt speaker."
The 12" woofer is only 80 watts.  The other 40 watts is attributed to the tweeter for a total of 120 watts per side.
#7 guitardad123
guitardad123
    Iknowathingortwo
  • PipPip
  • 205 posts
Posted 07 December 2017 - 01:42 PM
300RFL06-9
If that is the spec sheet then that's not a bad speaker for modeling amp. I would have to see this get a 101db Sensitivity rating measured across bands to believe that spec. You get those ratings in much more high end speakers, not these. How they acquire that measurement is another thing often debated in audio land.
The wattage is measured in RMS according to their spec so 70W RMS (music power or peak would be about 100W). Wattage is more in what the speaker can handle. Loudness is more based on SPL or efficiency of the speakers. I would not get too upset that are not $175 speakers in a $500 amp with all the bells and whistles of the 240.
Pretty sure these speakers are full range or maybe PA grade speakers. They don't have a widely extended midrange bump like guitar speakers do. That's why they also don't color the amp models and cab models and work more like a modeler with powered monitors used in PA's. If you used guitar speakers in this, you would "color" and or even limit the amp modeling with the freq response of whatever type guitar speaker you wanted to use. Speaker impedance is more directly related to power. Use a higher impedance speaker and you can lower the output. Some full range speakers with high efficiency (sensitivity) ratings may perform quite well or even be louder. Speakers like Eminence Beta 12CX have a good LF response, great upper mid band of 4.8Khz which is very close to guitar speaker spec. These are used as replacements in many wedge monitors or powered speakers. If my Spider V speakers blew I'd replace them with a Beta 12CX. Even though they are 8 ohms, I think what loss in power (if any was noticeable) would be made up in efficiency of the Eminence speaker.
Another good choice would be Beta 12LTA. I have used those with a 212 cab, solid state rack power amp for my POD HD500x. It sounded just fine. That speaker is a coaxial with range as high as 9Khz so it would be fine even for the drum machines. Not quite as extended as having a tweeter with it, but that can also be good since it cuts back any hissing of pizeo speakers. Those are the two I would try if I wanted to maintain the amp and cab modeling in the Spider V 120 or 240. The power ratings on those are even higher, but in terms of magnet size they are not much different that the Line 6 factory speakers. Magnet size is not really a big deal in guitar speakers. Look for efficient speaker with a broader bandwidth closer to that of guitar speakers.
If you wanted a semi open cab option you could just cut the size out from the lower half of the back cover. Add wood bracing around the cutout area if you decided to use it closed back. The bass response would probably be reduced.
I'd wait till it was out of warranty though.
#8 fearuvthedark
fearuvthedark
  • 12 posts
Posted 07 December 2017 - 02:00 PM
The wattage is probably measured in peak instead of RMS so it's more like 56W RMS.
No, the speakers are 80 watts RMS :)
#9 guitardad123
guitardad123
    Iknowathingortwo
  • PipPip
  • 205 posts
Posted 07 December 2017 - 02:07 PM
yeah I saw that... their spec says 70 RMS. Close enough  B)
  • 1
#10 thorneven
thorneven
    Iknowathingortwo
  • PipPip
  • 318 posts
  • Location"Upstate" New York
  • Registered Products:9
Posted 08 December 2017 - 07:59 AM
I was glad to see that Line6 finally closed the back of the Spider V series.  My drummer always complained that the sound coming out the back of my amp was deafening at gigs (especially when there was a reflective wall behind the stage).  Plus the sound that emanates out the front is fuller now with the closed back and I prefer that all the sound the speaker has to offer not get lost out the back of the amp.
1969 Les Paul Custom / Spider V 120 (studio) & 240 (stage) / FBV 3.  FORMERLY: JTV-59 + Pod HD500X + Spider IV, Vetta 2 / Behringer FCB1010. HISTORY: Spider IV, Spider III, AX212, Marshall, Acoustic, and various preamp + amp rack componentry.
#11 guitardad123
guitardad123
    Iknowathingortwo
  • PipPip
  • 205 posts
Posted 08 December 2017 - 01:26 PM
It would also be strange trying to emulate the closed back cabs in the models using an open back design.
